LS1 Accessory Drive Set
Old Feb 28, 2012 | 06:51 PM
croozer's Avatar
Does anyone know the P/N for this, or know where I can find it at. I have been looking and can't find it anywhere. I know that I saw it on here once. but can't find it back.
Croozer
Old Feb 28, 2012 | 07:02 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
Re: LS1 Accessory Drive Set
i have a power steering pump with pulley, crank pulley and alternator with bracket if you are interested. bought it off a 60k miles worked great, i just switched over to custom procharger accessories. if u are interested pm me.
Old Feb 28, 2012 | 07:10 PM
croozer's Avatar
PM Sent
Old Feb 28, 2012 | 07:14 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
It is no longer made. You can't buy LS1 F body accessory drive from GM any more.
Nook and Tranny pieces together a kit but it is crazy expensive.
Old Feb 28, 2012 | 08:20 PM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
look around on ls1tech....that is where I found mine. I got a pretty good deal too.
Old Feb 29, 2012 | 08:28 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
As far as I know, the only part that's discontinued is the power steering pump bracket. Everything else should still be available from GM.
Old Feb 29, 2012 | 07:50 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i too found mine on ls1tech after a few months of stalking the classified ads. sad they discontinued parts for the #1 option package for us 3rd gen swappers (and many others). i paid more for my brackets than i did for my 5.3 long block. add the alt, ps pump, water pump, and oil pan and I'm almost at 4 figures for just the swap trim!
Old Feb 29, 2012 | 08:01 PM
croozer's Avatar
Yikes!!! I'm looking for A/C compessor and bracket and tensioner, Water pump, main belt tensioner, and if 90-irocdx3 doesn't have it, then a power steering pump bracket... the discontinued part. Sad day, and i got my tax return back today even.
croozer
Old Feb 29, 2012 | 09:20 PM
Jim85IROC's Avatar
I got lucky and just scored a compressor and bracket/tensioner over the weekend. Hopefully the rest of the crap I need can just come from the dealer. The problem is, with Compnine gone, I can't even get the damned part numbers for these things. I printed out a pile of diagrams & parts lists from Compnine (holy crap was that a lucky foresight!!!), but the diagram that shows the accessory drive isn't one of them.
All I have left now is the rear alternator bracket, power steering pulley and the idler pulley that goes on the alt. bracket. I know the rear alternator bracket is still available at the dealer, but I'm not sure about the pullies yet. With any luck those pullies are still used on enough cars that they're still available.
Old Feb 29, 2012 | 09:42 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
LS1 GTO has same A/C bracket as F body (just has an extra boss or something). You can use that and can buy it new if you like.
Old Mar 6, 2012 | 12:51 AM
stereojnky's Avatar
Car: 1992 Rs
This might help. Not sure if the part numbers are current.
http://ls1tech.com/forums/conversion...t-99-02-a.html
Post #56 http://ls1tech.com/forums/15544649-post56.html Has part numbers. Again, not sure if they are correct.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
