lsx swap harness questions.
Old Mar 2, 2012 | 01:12 AM
89maroconvrs's Avatar
Just got my 5.3 that came out of a 04 silverado that I'm swapping inti my iroc that I bought as a roller. The motor came with the full engine harness plus pcm can i just use that harness and add my gauges since ill have auto meter gauges? Thanks in advanced
Old Mar 2, 2012 | 06:57 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: lsx swap harness questions.
The only gauges that the pcm will controll is the tach and speedo, everything els gets signal strait from the sensor.
Old Mar 7, 2012 | 09:26 AM
JeepinGuru's Avatar
yup im doing the same thing using stock harness
stripped harness down to make custom length
lengthened / shortened wires to get where i want to mount pcm and rerouted wires taped back togather and will pull it off and re-loom it
Old Mar 9, 2012 | 12:39 AM
Thanks. So is there any special way you are adding wire? Or are you just running a new strand for longer instead of splicing in to existing wire?
Old Mar 9, 2012 | 11:17 AM
JeepinGuru's Avatar
just cutting the wire and shorten it or splice more wire in then solider the splices throw some heat shrink tubing over it and move on to the next
Jorlain
Aug 24, 2022 05:11 PM
midge54
Sep 2, 2020 07:13 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
jharrison5
Aug 19, 2015 05:53 PM
squiggy2
Aug 9, 2015 09:30 PM
