Think I found my Ls1 to do the swap. Help!
Car: 1991 Camaro RS
Engine: Transplant 350, Building 355
Axle/Gears: Stock
I found an Ls1 long block to do my swap it has everything but oil pan and pulleys. The major question right now is the starter mount is broken off. Is this something that can be fixed by welding hence it is a aluminum block? And also will i need a diferent oil pan to do the swap? Im getting it for only $300 In my mind i feel this is a steal... I may be wrong though, any thoughts?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Somebody is getting a deal, but I'm not sure it's you.
A longblock is a poor start for an LS1 swap. You have to add a whole bunch of things - f-body oil pan (and oil pump pickup, and windage tray), accessories, intake, throttle body, MAF, IAT, harness, PCM, transmission (and flexplate or flywheel/clutch, depending upon which type tranny you go with), and whatever sensors don't happen to be on the longblock.
While the starter mount might be repairable, most likely the engine will have to be disassembled down to the block to do it right.
1 Post
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Think I found my Ls1 to do the swap. Help!
Id avoid it and five7kid is right. The stuff not there is gonna add up quick and you will spend more
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
I agree with the others....besides for the job of fixing the starter mount...there are a lot of parts that you will need to buy....Take it from me, I started with an LQ4 short block and spent a ton of money on everything else. If I were you, I would wait it out and try to find a package deal. It will save a lot in the long run. Good Luck!!
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
I couldn't agree more with the above posters. Wait for a complete dropout or even a donor car. This seems to be a common thing with LS engines, someone thinking a bare longblock is a great deal. It is AFTER your car is set up and running with LS power, but definately not as a first step..
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Unless you already had a bad rotating assembly and wanted to buy that one for the inners, I would not buy a busted block. The prices on complete running ls1 have really dropped in price, even complete cars are 4,000 now in good shape.
Car: 1991 Camaro RS
Axle/Gears: Stock
Great info here guys thank you. My plan was to rip it down and make it "my" engine, but honestly im lost. I know it would be very expensive to build from ground up but it would also all be brand new stuff with no miles.
Car: 1984 Z28
it's pretty clear everyone said not to buy a busted starter block.
Car: 1991 Camaro RS
Axle/Gears: Stock
Yes indeed i see this. My ? though is say i buy another Ls1 or Lq4 or what have you... Im going to be ripping it down to bare bone. So whats the diference? Just the broken starter mount. Yes i would have to buy a bunch of bolt ons but id have to for another block anyways.. Im just trying to see everybodies point here not to buy it if im just going to do the same to another block?
Car: 1991 Camaro RS
Axle/Gears: Stock
Regardless if i get the block or not is there a link someone can give me on what all is needed to do the Ls swap? Iv tried searching the stickys my computer here at work is ****.
Car: 1984 Camaro
I think everyone (including me) is saying the broken starter mount isn't the show stopper, its attempting an entire LSX swap starting with nothing other than a bare long-block. Buying a bare LQ4/LM7/LQ9/etc creates the same problem......getting nickel and dimed to death (ok, $50 and $100'd) collecting all the parts needed to actually get it running.
Car: 1986 IROC-Z
Engine: LS1-ish
Transmission: T56 stage II
Axle/Gears: S60 4:10's
Not sure what stickies you were searching, but this pretty much covers it all: https://www.thirdgen.org/forums/ltx-...third-gen.html
There is also links either on here or ls1tech that explain how to repair the broken block, if you do indeed buy that one, and the correct new longer starter bolts to buy. If I come back across it, I will post it up for you. Keep searching!
Car: 1991 Camaro RS
Axle/Gears: Stock
I totally agree... I found another Ls motor its a 6.0 out of a 2001 silverado. This is the LQ4 correct? The guy wants $300 for it and comes with wire harness.
Car: 1991 Camaro RS
Axle/Gears: Stock
Have you talked to JJ's automotive in Mt Pleasant? They typically have drop outs for sale for a good deal. Also likely to have or get you the other parts missing from long blocks you were considering.
Like I said before, depends on your goals with this thing. If you want to rebuild it thats great but you can get ALOT of power out of stock internals witih nothing more than a rod bolt upgrade.
I'd just open it up, put in fresh bearings and check clearances to be sure its all in check, maybe re-ring it, and do the rod bolt upgrade/rod resizing. This will turn 7K rpms and support near 500whp all motor if you have the cam/heads to do so. Thats a very nasty motor.
Car: 1991 Camaro RS
Axle/Gears: Stock
But yea im going to listen to everybody and forget the "broken starter block" Im WAY more interested in this 6.0 block out of this silverado after reading alot in those forum link. Thats my intension, to tear down and build up really like the idea of L92 heads with the L76 intake. I could reuse the wire harness and computer from that silverado correct?
Car: 1991 Camaro RS
Axle/Gears: Stock
Called JJ's he has Ls1/T56 coming in next week, he isnt sure of the mileage but he said around $3000 - 3500. I just really dont have that right now which sucks because thats everything i need.... lol i think im finally getting what everyone is saying haha
Car: 1991 Camaro RS
Axle/Gears: Stock
You have the T56? If so SOLD. Ill buy it this weekend if your up here in PA, See if you can find out how much your buddy wants for his Ls2.
And how the hell did he strip the crank bolt?
If all else fails..buy the lq4 for $300 regardless and hide it for now somewhere.Look for a blown ls1 or very high milage ls1 from an fbody that has the accessories which should be pretty cheap too and just swap everything onto the lq4.Do you want to make the car manual or keep it auto because this will play big in your expenses aswell.Set a goal for the car and stick to that first..or else you will be never ending changes and turn into a money pit lol.You can always do the swap in budget stages too,stock manifolds,700r4,custom y pipe.
Car: 1991 Camaro RS
Axle/Gears: Stock
Car: 1991 Camaro RS
Axle/Gears: Stock
Car: 1991 Camaro RS
Axle/Gears: Stock
Well like i just told Orr89RocZ, Just talked with the junkyard and he told me the 6.0 from the 01 silverado's fuel rails have been stolen and the hood has been taken off. Sooo its been sitting in the rain with no fuel rails... back to square one i suppose Still looking.
Car: 1991 Camaro RS
Axle/Gears: Stock
Car: 1991 Camaro RS
Axle/Gears: Stock
Tell me if you guys think i should jump on this deal... 6.0 working engine with 150k on it LS6 intake and LS1 accessories for $1,300. What do you guys think?
Sounds pretty good to me. I do have a friend with an LS2 he was considering getting rid of. I am interested in it myself. Also have another friend with a ls2 shortblock with a bad piston on one of the cylinders. Needs replaced but he has a new piston for it. Dont think there is any bore damage.
NBrehm
08-25-2015 11:49 PM
