fuel line questions on ls1 swap
Old Mar 2, 2012 | 01:25 PM
513camarors91's Avatar
Car: 91 camaro rs
Engine: ls6
Transmission: mn12
Axle/Gears: s60 3.73
ok i have a ls1 out of a 04 gto.now i have only one line coming out of the fuel rail not two. i have a 02 ss tank that i plan on installing. i am trying to figure out if i have to run the vette filter or not. ive read so many things now i have confused myself.my plan was to run one line from the front and keep the regulator in the 02 tank and then run a 3rd or 4th gen filter. so if im correct i will not have to buy the vette filter with the fuel pressure reg. in it. need help asap.thanx...i put up pics of what i plan on running with the fuel rail i have
Attached Thumbnails fuel line questions on ls1 swap-filterandreturnlinefromrear.jpg   fuel line questions on ls1 swap-2712282600074167970s600x600q85.jpg
Old Mar 2, 2012 | 01:35 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: fuel line questions on ls1 swap
You run a vetter filter as the vette filter is the regulator. Then you run one line up to the fuel rail. Its that simple
Old Mar 2, 2012 | 01:55 PM
Car: 91 camaro rs
Engine: ls6
Transmission: mn12
so i can't use the 4th or 3rd gen filter like in the pic....and i would allso have to remove the reg. in the tank?
Old Mar 2, 2012 | 01:58 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
you stated that your using a 4th gen tank, they have a regulator built in, just run the lines in a stock 4th gen fashion with 4th gen filter but leave out the evap line and run the one line to the rail, no vette filter needed.
so your plan is correct...
Old Mar 2, 2012 | 02:00 PM
6SIX6's Avatar
Car: 89 IROC
Thats a first ive heard of a regulator being in the 4th gen tank? My set up is a 4th gen tank, vette filter and then to the fuel rail
Old Mar 2, 2012 | 02:02 PM
and make sure you bolt that fuel rail to the intake... i noticed there was a glue gun next to it.
Old Mar 2, 2012 | 02:14 PM
Car: 91 camaro rs
Engine: ls6
Transmission: mn12
got the pic off the internet...so i can run the 4th gen tank with the built in reg. and the fuel rail that i have that has the fuel pressure reg built into it as well as shown it the pic up top.and run the 3rd gen or 4th gen filter correct
Old Mar 2, 2012 | 02:21 PM
yes. best bet is find a jy with a 4th gen not dismantled like a pick n pull and disconnect the fuel line off the tank and cut the line where it kicks out near the front, then just add a compression fitting and add line up to the rail. thats how i did mine. easy. 3/8 line i believe.
Old Mar 2, 2012 | 02:46 PM
Car: 91 camaro rs
Engine: ls6
Transmission: mn12
then why are ppl using the vette filter and removing the reg in the tank?
Old Mar 3, 2012 | 10:54 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Ive never heard of anyone removing the regulator from the tank...?
I always thought the whole point of the vette filter was for the "return" function of the fuel system. Instead of the return being up at the fuel rail, its handled back at the tank/filter.
Never really looked into the vette filter much though because I just used the 4th gen set up. It fits right in place and worked 100% since it was hooked up exactly as it was in the 4th gen.
J.
Old Mar 3, 2012 | 03:55 PM
J.
i havent either man, best set-up is right there, 4th gen tank / filter / one line to rail. Simple.
Old Mar 3, 2012 | 05:09 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
With a 3rdgen tank there is no regulator to remove..never heard of that on here either.The process is simple to understand regardless which tank you are using.
3rdgen tank is simple,use the corvette filter/regulator and a single line upto the fuel rail.The return line also gets plumbed into the corvette filter/regulator.This is common for guys who dont want to swap fuel tanks.
4thgen tanks have the regulator built into its fuel pump assembly unit.All you need to do is run the feed line to the rail..you can put a filter wherever you wish.The pros and cons between 3rd vs 4th gen tanks have been discussed more than enough.. for emissions..weight, wiring of gauges etc.Wont get into that lol
From what i was told..dont know how true this is,but the regulator on the fuel rail itself isnt to regulate the fuel coming in..but more to have equal fuel pressure between either side of the fuel rail itself so that all 8 injectors have the same steady pressure of what is being feed to the rail.You still require a true regulator before the fuel rail at 50-60psi.Someone correct me if that is wrong or not..Im curious as to the true nature of the diaphragm on the rail or is it serving a purpose of the returnless system?
Old Mar 4, 2012 | 09:12 AM
All the information is on the board to improve over stock parts and makes the swap easier
-plastic 4th gen tank, lighter, rust free, ready to run an LSx
-the new sender in the 4th gen tank is more accurate 40-240 ohm VS 0-90 ohm, larger scale = greater accuracy
-worried about the gauge? go read 750 L98's thread on the simple resistor swap, costs like $2 from the shack, maybe another $10 if you dont have a solder gun
simple simple
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
