Pully Alignment tricks
Old Mar 9, 2012 | 09:53 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
I need a cheap or free way to check my pully alignment. I am relocating my alt. And I want to make sure its strait so I don't have to fight it throwing belts. Any tips or tricks?
Old Mar 9, 2012 | 10:32 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Pully Alignment tricks
might sound kinda simple, but i use a straight edge like a level. do the best i can, check it 10 times.
Old Mar 10, 2012 | 06:23 AM
Brando5641's Avatar
Well I don't think that is going to work much better than just having the belt on it and eyeballin it.
Old Mar 10, 2012 | 07:38 AM
rongreen's Avatar
Car: 1938 Chevy 2 dr Sedan
Engine: Dart400 AFR190 TPIS ZZ409 Big Mouth
Transmission: Gearstar 700R4 level 4
Axle/Gears: Moser 12bolt-Det Trac loc 3:42
I agree with the straight edge if it is "true"(straight) how do you know that the belt is not shifted forward and aft slightly other than eyeball?
A small laser light will work if you can mount it parallel to your reference pulley.
Old Mar 10, 2012 | 11:22 AM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
Straight edge too.
Place it across the the crank pulley. Flat against the front of the pulley surface, with the end of your straight edge extending to the other pulley of concern. Confirm distance to the center rib of each pulley is the same distance.
Can check each pulley individually against the to/from pulley that the belt path travels.
Old Mar 10, 2012 | 11:54 AM
Brando5641's Avatar
Originally Posted by HP52TA
Straight edge too.
Great idea! I will be trying this. That never even crossed my mind lol thanks.
Old Mar 10, 2012 | 12:02 PM
rongreen's Avatar
HP52TA you did a much job of explaining what we thought was understood.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
RS Reaper
Sep 27, 2015 07:04 PM
89 formula TPI
Sep 20, 2015 10:54 AM
