PCM bracket?
Old Mar 10, 2012 | 07:12 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
PCM bracket?
Is there a bracket for the 4thgen pcms (and does anyone have one?) or are they just shoved over the hvac box? I can't seem to find GOOD pictures of the area to see. It looks like there is...
Old Mar 11, 2012 | 09:34 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: PCM bracket?
yes, look on e-bay they usually have good pictures of ones people are trying to sell for more than dealer prices. (two styles... 98 and 99-02) the pcm slides into it. some call it a bucket.
I like the truck bracket for 99-02 myself usually the s10 one works great and is sturdy allowing for modifications of added brackets
Old Apr 21, 2012 | 08:48 PM
stereojnky's Avatar
Car: 1992 Rs
Re: PCM bracket?
I've got one from an s10 if you still need a picture of it.
Old Apr 21, 2012 | 10:37 PM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
Re: PCM bracket?
I have one from an 02 that I won't be using.
Old Apr 22, 2012 | 12:35 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: PCM bracket?
There is a plastic holder that the PCM slips in (no screws). The holder rests on the fender and is held in place with two screws at the top near the shock tower.
This thread might be helpful. http://ls1tech.com/forums/conversion...g-options.html I think for what you're doing, the IronWorks brackets might work best.
Old Apr 22, 2012 | 12:46 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: PCM bracket?
I actually found that thread a few hours after making this thread and the ironworks bracket is what I mimicked when I made mine. Just a bit of flat stock and couple minutes with the welder.
Old Apr 27, 2012 | 10:04 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: PCM bracket?
I got mine shoved up under the dash on the pass side. The cover that goes down there is helping hold it in, no rattles.
Old Apr 28, 2012 | 06:04 AM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
Re: PCM bracket?
I did the same with my PCM. Its wedged up and doesn't seem to move.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
armybyrd
Sep 26, 2015 03:37 PM
