Charging issues...
Old Mar 14, 2012 | 09:51 AM
Sgtweedy's Avatar
Car: 1986 Iroc-Z Camaro
Charging issues...
I apologize if something like this was already posted, but I'm in Afghanistan and I only get 30 mins of computer time. So a few years back I swapped an LS1 into my '86 IROC-Z. Turns out it was a pretty big project, alot more than I expected. My problem is I can't get the battery to hold a charge. I used all the existing parts from before, minus the new alternator and new battery. Not only that, but the horn is extremely weak, as are the headlights, mostly on the passenger side. After I shut it off I can't get it to start again. I'm going on leave soon, so I'd like to get it running to drive it a bit. I'm wondering if I forgot a strap or something along the way. Any help would be greatly appreciated!!
Old Mar 15, 2012 | 09:06 AM
Rpk250's Avatar
Car: 91 Camaro RS - 87 Buick GN
Engine: LS6 - Turbo Buick
Transmission: 4l60E - 200R4
Re: Charging issues...
Did you check for a draw?
Old Mar 16, 2012 | 06:39 AM
Sgtweedy's Avatar
What is a draw?
Old Mar 17, 2012 | 10:31 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Are all your grounds bolted down in the headlight harness?
Old Mar 17, 2012 | 11:10 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
i dont have any charging issues but I did my best to make sure of that not happening.I got 4ga grounds on the front and back both heads direct to the frame and battery.4ga from the battery to the alternator hen to the starter.i have an upgraded truck alternator good to 160amps at idle which i recommend to everyone doing an lsx swap to use this.The alt has a single wire going from it to the ecm and thats it.
Old Mar 19, 2012 | 11:21 PM
Sgtweedy's Avatar
I appreciate the help. I think the headlight harness is grounded, but that's something that I can check. As for grounding the heads and stuff, is that something that is recommended? It wouldn't be hard at all. And 86 White_T you said you used 4ga. Does it matter what type? Should it be weather proof, or would like speaker wire work?
Old Mar 20, 2012 | 12:42 AM
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
did this too, as is always suggested on this site, worked wonders bro. constant good charge on the meter.
Old Mar 20, 2012 | 09:21 AM
Sgtweedy's Avatar
Alright man, I'll give it a try. Gonna have a few days to mess with it while I'm home for two weeks, so I'll see what happens.
Falcon50
Aug 22, 2020 03:26 PM
apie2546
Oct 16, 2016 02:24 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
