93 LT1 TCC Wiring
Old Mar 25, 2012 | 05:26 PM
MRose's Avatar
93 LT1 TCC Wiring
Hey guys, I'm going over the wiring on my '88 GTA which has a '93 FBody LT1 in it.
I'm pretty confused with the TCC interface points. From what I can tell I have the following:
On the car:
C207 H (tan/blk) - as far as I can tell this goes to the ALDL pin F
C207 P (ppl) - to brake switch (is it +12v or ground)? Not sure my car has this either.
C100 E7 (ppl) - ?
On the '93 LT1 harness:
C230 H (lt blu) - Switched TCC power feed
C230 K (tan/blk) - TCC control
Where should the two wires from the LT1 C230 go?
Old Mar 28, 2012 | 07:35 PM
MRose's Avatar
Re: 93 LT1 TCC Wiring
On the car:
C100 E7 (ppl) - ?
Someone has to have done this before.
C207P does not exist on my car. So I'm guessing I have to wire C100 E7 (ppl) to the ecm's LT1 C230 H (lt blue). From what I understand, this provides power for the tcc solenoid whenever the brake pedal is not depressed.
The remaining wire, C207 H (tan/blk) connects to LT1 C230 K (tan/blk) and tells the ecm to lockup the converter when someone grounds the correct ALDL pin.
Is this correct?
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
jklein337
Sep 19, 2018 06:23 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Aug 29, 2015 09:51 PM
