How to loop heater lines at waterpump?
Old May 1, 2012 | 09:36 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
I just want to "u" the lines together at the waterpump.
Old May 1, 2012 | 09:54 PM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Re: How to loop heater lines at waterpump?
Coolant leaves the intake manifold and needs to return to the water pump or radiator.
Old May 1, 2012 | 10:12 PM
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Negative...you need a gates b87629 hose to connect the water pump outlet/inl. Any parts store should be able to get it quickly.
Old May 2, 2012 | 07:15 AM
Z28 MeTaL HeAd's Avatar
Engine: Carb'd LT1 w/ a Cam :)
Axle/Gears: Moser 9" w/ 3.75 gears
There is no coolant running into the Intake on an LT1 or LS1...
Old May 2, 2012 | 04:15 PM
Car: 91 z28
Transmission: 4L60e
Fits like a glove, right off the shelve. Clears frame rails. About $10.00 at Autozone. Thank you, Aviator
Old May 2, 2012 | 05:08 PM
Car: 1984 Camaro
Heh, glad to help. I tried to record part numbers of all the random Crap I bought for the swap just for questions like that...
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
buckshot63
Sep 10, 2015 09:15 AM
TBRays98
Sep 6, 2015 05:05 PM
