LS1 Fuel System
Old May 3, 2012 | 07:52 AM
29 Ford Pickup's Avatar
LS1 Fuel System
I am building a 29 Ford Pickup street rod. I installed a LS1 with a 4L60E out of a 2000 Camero. I used a fuel tank out of a 2004 GTO which fit well in the bed. I have the stock fuel pump set up in the tank. Now, I am confused on how to plumb the fuel lines. Two lines currently on the engine and two on the tank. However, I believe the top large line on the fuel pump is the evap line. Looking for advise on the proper line hookup from the tank to the engine.
Old May 3, 2012 | 08:16 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Re: LS1 Fuel System
Search the LSX forum, been covered many times.
Old May 3, 2012 | 11:08 AM
Re: LS1 Fuel System
Thanks - at 50 something I am new to using these forums. I don't see if I just cap off the Evap opening on top of the stock 04 GTO tunk fuel pump because I don't plan to use that port??
Old May 3, 2012 | 06:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
50-something? Claiming to be too young to understand????
Okay, I understand these things can be confusing, and different Boards do different layouts.
So, welcome aboard thirdgen.org.
Be aware that this Board is dedicated to 3rd gen GM f-bodies. As long as the topic can be applied to 3rd gens, it'll be allowed. Just don't get distracted with talk about mounting the LS into the '29 frame, for instance.
Oh, I moved this to the LS swap subforum...
Old May 4, 2012 | 08:19 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: LS1 Fuel System
https://www.thirdgen.org/forums/ltx-...third-gen.html
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
NBrehm
Aug 25, 2015 11:49 PM
