Thinking about swaping a Vortec 5300 series in, Possible?
Car: 1984 Camaro Z28
I am looking at swapping a Vortec gen 5300 in my Trans Am The motor is a truck motor I would like it since it has a decent amount on power, fuel economy is great and its a extremely reliable motor, I have it in my truck, the valves and the lifts make a ticking noise but damn does it ever run strong!
http://img.orbitbid.com/2010/10/11/409921%20009.jpg
Car: '83 z/28
Axle/Gears: Stock?
Re: Thinking about swaping a Vortec 5300 series in, Possible?
Search man. Hundreds if not thousands of people have done it before you.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
If you are talking about the LM7, it is really no different than any L-series engine.
Just a matter of intake to intake to hood & accessory to crossmember clearance.
Car: GTA
Then just think of it is a LQ9 when doing your reading, as there is very little difference besides the programming & maybe the exhaust header tubing side. But just thrown on some 98+ F-body headers/exhaust manifolds & your good to go. Or if you read "5.3 swap"? That is the 5300. Tons of info here on TGO about it.
The LM7 is done just as much as a LS1. Just requires the changes I mentioned above vs the LS1.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Dude, there's a sticky right at the top of this very forum:
https://www.thirdgen.org/forums/engi...third-gen.html
There's also an entire forum devoted to this swap:
https://www.thirdgen.org/forums/ltx-lsx/
Transmission: 4L80E/4L80E
Read the LS1 swap sticky. Be sure to click on the link about starting with a truck engine.
The "ticking" you hear is probably piston slap. Very common, not an issue.
hectre13
Dec 11, 2023 08:14 AM
Fast355
Dec 2, 2016 06:33 PM
hectre13
Aug 26, 2015 08:17 AM
knight72
Aug 10, 2015 09:32 PM
