How do i wire up an electric fuel pump in an originally carb'b car?
Old May 7, 2012 | 04:48 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
Hey, im looking into doing an ls1 swap in my 86. The car is currently carbed with a 305 and 700r4. For the fuel pump, how would i go about wiring up the in tank electric fuel pump? Would i have to buy a harness, or is the pump wiring already exsisting in the fuel sending wiring? Any info would be a big help, thanks
Old May 7, 2012 | 11:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No, the wiring isn't there.
I've done two, and I did it differently for each.
The first I put a 4th gen LS fuel tank in and used its pump. I ran a wire from a swap fuse/relay box in the engine compartment through the passenger compartment back to the tank.
The second I bought an EFI pick-up assembly from a TGO member and installed a Walbro pump in it. That LS1 drop-out included the 4th gen fuse/relay boxes, so again I ran a wire from it in the engine compartment back to the tank through the passenger compartment.
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
86IROC112
Aug 17, 2015 02:00 PM
djmarch
Aug 9, 2015 05:27 PM
Kaweh
Aug 9, 2015 02:54 PM
