LT1 swap motor mount question
Old May 20, 2012 | 07:55 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I searched for different motor mount threads here but I didn't find what I was looking for.
I just need to know which motor mount "stands" on the engine side do I need to use for an LT1 swap? I'm using Corvette accessories which is supposedly going to make things a lot easier. I have the rubber mounts that are for a third gen for the k-member side, but I'm not sure which stands or receives if you want to call them that, should I use? Will the 4th gen ones work or do I just need to find a set out of a 3rd gen with a 305/350?
Thanks.
Old May 20, 2012 | 08:15 PM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Re: LT1 swap motor mount question
On my LT1 swap and my dads I used the stock 305 mounts that bolt to the engine on the LT1. I had to modify the passenger side one to clear the AC compressor though, but I was using f-body accessories.
Old May 20, 2012 | 09:01 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Stock thirdgen mounts
Old May 22, 2012 | 04:51 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
+1
You will need to re-use your current ThirdGen "clamshells" too.
Drivers side clamshell is on the Left and Passenger side clamshell is on the Right.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
