408 lsx tuned and dyno
Old May 26, 2012 | 12:12 AM
mikebondi's Avatar
Car: 91 Camaro RS
Engine: 6.0 lq9 ls bored to 408
Transmission: T56 6 speed
Axle/Gears: strange s60 4.10 with a spool
Just got back for a.i.r or American intense racing here in Denver. Clint did some work and tuned and dynoed it for me. Great guy very good at what he does.
Car put down 422 rwhp and 426 rwtq n/a.
Numbers are on a dynojet.
It needs better heads and a new intake. But I need to do the rear end first.
Overall super happy with it.
Old May 26, 2012 | 02:19 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Re: 408 lsx tuned and dyno
Just saw your avatar did you have this car up on eBay for sale awhile back ?
Old May 26, 2012 | 07:37 AM
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Nice dyno numbers! I'd be super happy with that too! Yeah, I think you'd be pushing your luck if you continue to beat on that 10 bolt. What are your plans for the rearend?
Old May 26, 2012 | 08:40 AM
mikebondi's Avatar
Car: 91 Camaro RS
Yes it was just up on eBay. I just bought it about 2 weeks ago.
yeah the rear is built but I don't think it will hold what it has right now let alone an additional 175 shot of nos. I'm going to go strange s60. I just need to get the swap all finished there are some odd thing that need finished. Just changed the oil pan and the exhaust is cool but not practical and is welded solid and to the frame.
Old May 26, 2012 | 04:00 PM
dprest68's Avatar
Engine: cammed LS1
Yeah, I was thinking the same thing about the rearend. I was looking at the s60 too. Seems a little more affordable than the alternatives. Sounds like that exhaust is going to fun to fix. Good luck with it.
Old May 27, 2012 | 10:13 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Worst thing about the S60 is no gears taller than 3.54:1. There used to be 3.31:1, but good luck finding a set. A 408 LSx with spray just doesn't need a whole lot of rear gear. Most of your improvement will be in the torque converter. Plus the S60 is heavier and far more money than doing your own Ford 8.8" swap. A 33-spline 8.8" with a rear cover will hold your proposed 600 RWHP, and adds gearing choices of 2.73:1, 3.08:1, 3.27:1 and 3.31:1
Old May 27, 2012 | 08:26 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
that seems extremely low... my 364 ci ls2 made 468/440
Old May 27, 2012 | 08:34 PM
mr305's Avatar
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
x2
my buddies cammed stage 2.5 headed LS1 made 418 rwhp
Old May 27, 2012 | 09:06 PM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Those numbers are horrible. My old truck with a 6.0 stock bottom made 470rwhp through a 4l80e and the 14bolt.
Old May 27, 2012 | 10:28 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
DENVER guys... ya know.. MILE HIGH.. and all.. sheesh..
Old May 28, 2012 | 02:28 PM
mikebondi's Avatar
Car: 91 Camaro RS
thanks raver.
as anyone that has 400 plus hp knows its still a fun ride. now that said i surely want more.
couple things holding it back.
1 5280 feet elevation.
2 stock ls6 heads with just comp cam springs
3 stock ls6 intake
4 1 5/8 inch long tubes. not sure how much im leaving on the table here.
big cam without heads is cool but it doesnt make the power it should without the heads.
the heads and cam will be a coming attraction. i need to squeak threw etest and get my rear end and drive shaft upgraded. then its back to the horsepower side of it
Old May 29, 2012 | 03:21 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
Axle/Gears: moser 4:10
-3 to 4 percent horsepower per 1000 ft of elevation. On average.
Old May 29, 2012 | 03:48 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Wouldn't the SAE-corrected dyno numbers take elevation (or for that matter, all atmospheric conditions) into account?
Old May 29, 2012 | 04:13 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
Yes. Unless they just show observed HP.
Old May 29, 2012 | 08:59 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
When I saw your numbers my first reaction was...
Now the low numbers make more sense. It's very common place for a 408 to make 500+ RWHP. Uncork that thing and get some air flow through it.
Old May 30, 2012 | 07:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I guess "taller" means different things to different people.
The S60 may be heavier, but it is bolt-in vs. an 8.8 swap. I've only seen comparisons to 9" and 12-bolt, but the S60 is more efficient than either of them (9" being the least efficient).
I can't imagine needing a ratio lower than 3.54 for a track-primary car. A taller tire can be used if necessary. My LS1/T56 car went through the traps at 6000 RPMs with 4.56 gears and 26" tires. If I were to take the car to a lower elevation, I'd put 27" tires on it.
Old May 30, 2012 | 08:16 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I ported a set of 317s for a friend with a 408, made 460 to the ground, ran out of fuel at 6500, stock injectors, I did not have polishing bits, so it was not as I like, polished. Swapped a fast intake and full length headers, made over 500, so I have faith in my porting abilities, lol.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
