lt1 swap info
Old May 28, 2012 | 12:26 PM
87iz28383's Avatar
Car: 87 Iroc
Engine: 305 for now
Axle/Gears: 10 bolt posi 3.08 gears
lt1 swap info
been looking at at doing a swap in my 87 iroc with the pooped out 305 was gonna go with a carb 383 but found some pretty good prices on lt1s and thought bout going this route instead just wanting some info from ppl that may have already done this swap
how difficult was it how bad is the wiring what kind of oil pan and front drive system will i need i know they differ from the corvette to the camaro, caprice also heard something bout getting the computer reprogrammed what year would be the best just trying to get some thoughts or should i just stick to the carbed 383 or maybe just the tpi thats in it having a hard time deciding also wanna go from auto to manual and i know the t5 isnt that strong also another reason for going with the lt1 so i can have the t56 6spd let me know your thoughts and ideas any help making up my mind would be great lol
Old May 28, 2012 | 01:06 PM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
Re: lt1 swap info
look into the LT1/LSX specific area there is a lot of info to filter through. I would recommend Pocket for the wire harness. It saves a lot of headache. Mechanically it'll bolt right up to the transmission and the clam shell motor mounts will bolt right up to the engine. you will have to do some modifying if you are going to use the f-body A/C and accessories. It's only minor cut/welding. read through all the info to figure out your goals, and then take it from there.
Old May 28, 2012 | 01:29 PM
87iz28383's Avatar
Car: 87 Iroc
Engine: 305 for now
Re: lt1 swap info
thanks for the help still not sure which way i wanna go do you think the stock rearend will hold up to a stock lt1 and t56 or should i just save up to replace it while i have the car down the rearends in the 4th gens are the same arent they just a little wider
Old May 28, 2012 | 03:52 PM
Car: 86 Camaro Z28
Re: lt1 swap info
it all depends on how you treat them. I haven't put any serious power to one yet, until my build is finished. They are the same diff, just depending on the year depends on the type of LSD. I'm running a putting a 4th gen in for the brakes and LSD. I can't budget anything stronger right now. There is also a lot of info on those in the drivetrain section.
Old May 28, 2012 | 04:12 PM
Lt1Chris's Avatar
Car: 01 Acura TL
Engine: 3.2 Vtec
Transmission: 5 speed
Axle/Gears: ?
Re: lt1 swap info
ill sell you my lt1 , ecm,and harness for 900 going back to factory v6
Old May 28, 2012 | 05:53 PM
87iz28383's Avatar
Car: 87 Iroc
Engine: 305 for now
Re: lt1 swap info
that sounds like a hell of a deal anything done to the motor do you have any picts?
Old May 28, 2012 | 10:01 PM
Car: 86 Camaro Z28
Re: lt1 swap info
no questions, just buy. lol
Old May 28, 2012 | 10:42 PM
87iz28383's Avatar
Car: 87 Iroc
Engine: 305 for now
Re: lt1 swap info
lol i plan on it just gotta round up 900 extra dollars
Old May 29, 2012 | 01:37 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: lt1 swap info
Put a carb on a LT1 ; problem solved
http://www.ebay.com/itm/GM-Performan...d6fea5&vxp=mtr
Old May 29, 2012 | 02:41 PM
87iz28383's Avatar
Car: 87 Iroc
Engine: 305 for now
Re: lt1 swap info
No thanks lol
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
