Fuel Pump TPI to LT1?
Old Jun 8, 2012 | 03:43 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
OK i've been using the stock TPI fuel pump in my 87 for the past 5 years with the LT1- no issues at all.....it only recently occurred to me that the fuel pump is now 25 years old! Since i am swapping out the rear axle in the next few weeks i thought it would be a good time to dig out the fuel pump and replace it....the question is should i look for a higher flow rate pump? future plans include either a bigger cam/rockers...or maybe a procharger.....i really don't want to have to do this again for obvious reasons......so any thoughts? thanks pat
Old Jun 9, 2012 | 01:01 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Re: Fuel Pump TPI to LT1?
Walbro 255 it, and call it good
Old Jun 9, 2012 | 06:39 AM
hotrodln's Avatar
Engine: Lt1 in IROC
what kind of flow rate do they put out in comparison to stocK?
Old Jun 9, 2012 | 12:41 PM
evo-offer's Avatar
don´t forget the fuel preassure regulator if the stock don´t can handle the new pump
Old Jun 10, 2012 | 04:52 AM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Trust me the stock **** can handle the piece perfect, no fuel pressure regulator needed man. Next time comment when you know for sure.
Old Jun 10, 2012 | 05:28 AM
evo-offer's Avatar
okey so the stock regulator can handle a walbro 255 pump? maybe ot but the ls1 engine does require a new regulator? i did mixed it up with the ls1 and lt1 engine.
Old Jun 10, 2012 | 07:20 AM
hotrodln's Avatar
Engine: Lt1 in IROC
ok so the walbro is the way to go? i installed one in my son's 3000gt and it failed 6 months later.....replaced it with a Denso...no problems yet...
Old Jun 10, 2012 | 08:20 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
if you go forced induction a external fuel pressure reg. with the 1:1 rising rate is a good idea .
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
