help with an ls1 potential purchase
Old Jul 2, 2012 | 12:45 AM
rivsrul's Avatar
Hello everyone,
thanks in advance for your input. Ok I have a couple f bodies and I am complating putting in a ls1 in my 69 firebird. Now I am familar with the basic process req'd and it can quite expensive as well all know. I have just run across a deal on craigslist for a wrecked ws6 ls1 t56 drop out. He is wanting 3900.00 for the whole setup with 108k on it. Do we think that is fair price ideas?? comments? thanks Phil check out link for further info http://lasvegas.craigslist.org/pts/3108338399.html
Old Jul 2, 2012 | 02:38 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: help with an ls1 potential purchase
For a setup like that - I'd offer him 3200 or so. Once you start reaching the $4K mark you can get some nicer low(er) mileage setups.
Old Jul 2, 2012 | 07:56 PM
CAMAROJOKESTER's Avatar
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
for that price you might want to consider building one up. I would be cautious about the engine and how the driver drove it giving that it is a WS6, they may have driven it hard.
Old Jul 3, 2012 | 03:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I respectfully disagree. T56 dropouts are quite a bit more than 4L60E's. And, this one has upgraded cam, injectors, tranny and clutch. Probably upgraded tune as well (although you'll still need to tune out some stuff like emissions).
The 9" would be worth pursuing as well (although wouldn't be a bolt-in into a '69).
Old Jul 3, 2012 | 04:59 PM
Marc 85Z28's Avatar
About $1000 too high. I've seen several wrecked LS1 T56 cars go for under $4000 in the last few months.
Old Jul 3, 2012 | 05:13 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
yeah just look around you could find engines like these for cheap just have to patient i just found one for $250 and ima build it up just got to wait for the right deal.
Old Jul 3, 2012 | 06:07 PM
five7kid's Avatar
With those upgrades?
Old Jul 3, 2012 | 06:45 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Id say offering $3200 cash is fair.They key to this dropout is you are saving since it has upgrades that would cost you more had you bought this all seperately.T56's stock still range anywhere from 1200-1900 used,l1's can be had cheap $500 upto 1200.Fbody front accessories arent cheap to buy new either,then engine harness and computer thats already tuned to the setup.Stage 2 trans build ontop..and clutch.
If its running good with no signs of major abuse I dont see why this is a bad buy?
Buying the motor piece by piece upto the same level as this combo would be over 4grand price tag aside from whatever swap parts you need to put it into the 69.
He could find a cheaper engine with lower mileage sure..but it wont be as complete as this dollar per dollar.If you have the chance to grab the entire car for 3900 as it sits then that would be a good bargain for a donor car.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
aharvel50
Sep 21, 2015 07:31 PM
86White_T/A305
Sep 21, 2015 05:28 PM
dbrochard
Sep 19, 2015 08:13 PM
timonator
Sep 17, 2015 06:57 PM
