compatible fuel injector plugs
Ok, so I have been tinkering with my harness little by little over the last several months. I'll pick it up then put it down for a while. It was originally an LM7 harness from an '01 tahoe. So I need to get new injector connectors, I've seen sets of pigtails from $60 on up, then I stumbled across this:
http://www.ebay.com/itm/LSx-LS1-LS2-...046dfd&vxp=mtr
They look very similar, and the price is right. Has anyone tried these or heard of them being used? It seems that they are off of Ford harnesses so I wasn't sure.
Thanks!
Croozer
Thanks!
Croozer
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: compatible fuel injector plugs
Those look right for the truck injectors, however unless for some reason you are using the truck intake manifold, generally with the car manifolds and rails you use regular tall injectors that use the older bosch plugs.
Thanks!
Croozer
Thanks!
Croozer
Awesome! Thank you very much. I appreciate the response. I wasn't sure on it because it did look a little different, but I thought that it was just my eyes playing tricks on me. It said compatible with LS1, glad I asked. Thanks Z28Ricer, I appreciate it.
Croozer
Croozer
Car: 93 240SX
Engine: LQ9
I have just the bare pins if you want to crimp them on, I can set you up with a set of the connector bodies and the terminals for a reasonable price, jegs and summit both sell the crimp tool required to install them pretty cheap, and the end result is much better without a bunch of butt splices and/or soldering and heatshrink.
Thanks,
croozer
Firechicken86
Aug 12, 2015 10:07 PM
