bmr or spohn crossmember for my swap
Car: 1992 Camaro Z28
Engine: 5.0 TPI
Transmission: auto
I want to get one of these crossmembers with a-arms and coil overs. I am liking the BMR, anyone have any tips one way or the other. My 91 z28 is getting ready to accept the ls1/t56 from my 2000 z28. I plan on keeping the ls1 a/c and using Hawks long tubes.
thanks,
guys.
thanks,
guys.
Re: bmr or spohn crossmember for my swap
Of those, I would choose the BMR hands down.
Engine: 5.0 TPI
Transmission: auto
yea, i read the problems you encountered on your latest build, and i have had issues of my own with their d/s loop. thanks for the info
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Engine: 5.0 TPI
Transmission: auto
The BMR is going on my car, after reading many threads on here and hearing a few other horror stories about the other, my mind is made up.
thanks guys !
thanks guys !
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
BMR, as long as you going with the stock clam shell mounts. If you go with solid motor mounts on the block, you have no wiggle room to get things lined up due to there solid mounting point on the K member. I tried to no avail and ended up going with the stock mounts.
All accessories including A/C clear just fine and no steering link clearance issues.
BMR K member should be used with BMR A Arms, or the K-member may need to be clearanced, depending on A Arms used. I had Spohn A Arms before the BMR K member and had to modify the K member to get the A Arms to clearance at full squat. Can be done, but with mods.
Engine: 5.0 TPI
Transmission: auto
yea i plan to use the stock mounts but with the poly bushings. Also i am glad to know that a/c and all clears. I will be using BMR arms and coil over kit.
thanks for the info
thanks for the info
A little grinding on the solid mounts, making holes into slots and it drops right in. I do agree that the jigging could be a little better since I had to shim up some stuff here and there, mainly gaps on bushings.
ambainb
Apr 25, 2016 09:21 PM
