Fixing an LS6 intake. Help/thoughts/ideas please!
Old Jul 24, 2012 | 11:32 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
So after being the cheap *** I am, I finally found an LS6 intake for less than $400. I picked this guy up locally for $250, but it needs a little attention.
It's part #12573572 and originally came off of a Z06 vette. However it was put on an LS1 block with the steam tube so the previous owner has already clearanced the bottom of the intake. Sweet 1 less thing for me to do.
What I need some help with is fixing the home-brewed EGR port that was cut into the intake. It looks like it worked really well, but it's just something I need to fix. Here's what it looks like:
Question is how do I fill the hole after I removed the EGR input??!!
My thoughts so far would be to use some tape on one side of the hole then fill the other side with black epoxy.......any better ideas?!?!
Old Jul 24, 2012 | 11:43 PM
Car: '91 LS6/T56/9"
Engine: LS6
Re: Fixing an LS6 intake. Help/thoughts/ideas please!
This stuff looks promising:
http://solutions.3m.com/wps/portal/3...beQH8HT14PGTgl
Old Jul 24, 2012 | 11:54 PM
Car: '91 LS6/T56/9"
Engine: LS6
So the intake is made of Polyamide 6-6. Any idea where I could find something that's also made of that stuff so I could maybe cut out a patch?
Old Jul 25, 2012 | 12:43 AM
rock861261's Avatar
first you need to stop playing with that because its a slp intake and are worth big bucks because they are rare and second they are not off a zo6 its off a 2001 camaro ls6... 3rd that egr fitting is stock.
Old Jul 25, 2012 | 12:44 AM
rock861261's Avatar
http://www.jegs.com/InstallationInst.../847-30041.pdf
you just ruined a $600 intake...
Old Jul 25, 2012 | 12:45 AM
rock861261's Avatar
http://paceperformance.com/i-5155448...-firebird.html
Old Jul 25, 2012 | 12:46 AM
rock861261's Avatar
but to answer your question you can get some aircraft grade epoxy and replace it fairly easy.
Old Jul 25, 2012 | 01:24 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Epoxy it.Scuff the area with sand paper first and clean it well.Put tape on the inside and put a first thin layer and let it set so you know you have a solid base.Then add more to fill and seal the hole.Once its cured you might want to smooth the inside just for the air flow but not a big deal.Ive seen guys plastic weld ls6 intakes but its not easy to do right i hear.
Old Jul 25, 2012 | 06:58 AM
Car: '91 LS6/T56/9"
Engine: LS6
The only reason I didn't think it was an SLP intake is because I'd never seen a picture of one before. I need to be sure that someone didn't modify this on their own first........
I'd much rather have a stock intake than have to fix anything.
Old Jul 25, 2012 | 10:43 AM
Car: '91 LS6/T56/9"
Engine: LS6
Originally Posted by rock861261
I didn't ruin anything.........
Old Jul 25, 2012 | 06:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
12573572 is not an SLP part number.
Old Jul 25, 2012 | 06:17 PM
Car: '91 LS6/T56/9"
Engine: LS6
Of course it isn't because SLP only modded stock intakes. I've been emailing with SLP tech all day and they've confirmed that it's an SLP modded intake.
I've also found where to get the nut and ferrules to complete the intake so it'll be for sale ASAP since I've no need for an EGR provision, and I'd like to see someone get it that actually needs it.
Old Jul 25, 2012 | 10:41 PM
rock861261's Avatar
slp used the 572 intake from late 2000 - early 2001 before gm went with the smaller cam... all slps use the 572 intake however not all 572s are slp intakes.. however the intake came stock on slp camaros...
Old Jul 25, 2012 | 10:42 PM
rock861261's Avatar
all you would have to do is get a plug for it.
Old Jul 25, 2012 | 11:34 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
You can use a rubber expansion plug, they sell the at "Vato Zone" in the coolant hose section
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
Buggy Disaster
Sep 22, 2015 01:15 PM
sandman92084
Sep 12, 2015 10:27 PM
