86 Z28 cammed 5.3 swap
Old Aug 9, 2012 | 10:17 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
A fellow member here just swung by tonight and we dialed in the tune on his 86 Z, i figured i would share, it was a bit lean after getting the timing in and now she is spot on adter jetting up the primary a few sizes, it was only a bit rich. The cam is a custom grind 235/239, 110 LSA and .600 lift, milled 243 castings and a over the hill 200K plus 5.3 liter, go LS! Runs fantastic, 750 DP, 74P 78S jets, hawks swap headers with built 700R4, 3.90 gears in a 10 bolts. Has some clean up to do but this is his first time to drive it since the swap, he towed it to my place and drove it home. He had a 6.0, which the replacement pistons let go and now he went this route for temporary till he gets another 6.0 to increase power(or will there be a stroker?).
This thing runs like it should, i will say that!
Old Aug 9, 2012 | 11:07 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: 86 Z28 cammed 5.3 swap
Looks and sounds good.I vote for a nice carb 402/trex when he gets the 6.0 back up for a mild setup lol.
Old Aug 9, 2012 | 11:16 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Im guessing you ran that MSD controller box?
Old Aug 9, 2012 | 11:20 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
A Trex is not enough to feed a 400ci LS, not past 6400 RPM anyway, last one i helped a friend build was 258/264 @.050, the Trex is 242/248. So custom grind if he does go bigger!
It is in the pic, the 6010 box. Initial is now 20*, then ramps to 35* all in by 2000.
Old Apr 17, 2013 | 05:21 PM
LivinLarge's Avatar
What exhaust is on the car? Sounds awesome!
Old Apr 17, 2013 | 07:25 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Was a blowmaster single in dual out. I don't like them, they sound hollow and holding back. Not bad, but not my preference.
Old Apr 17, 2013 | 08:46 PM
LivinLarge's Avatar
I really liked how the single 10 series sounded on your red car!
Old Apr 18, 2013 | 12:50 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
1 chambers are kind of the exception. Not much chamber there to cause that holding back sound I think.
The car in this post has gone 7.4 with a 6.0 now. Same heads and cam the 5.3 used. 5.3 went 7.8s.
Old Apr 18, 2013 | 04:35 PM
LivinLarge's Avatar
Do the one chambers drone like hell like most flowmastes do?
Old Apr 18, 2013 | 04:59 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Pretty much.
Old Apr 18, 2013 | 05:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The only Flowmaster I've ever liked is the Force II I have on the LS1/T56 Berlinetta, and it doesn't even look like they offer it anymore.
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
nuggie
Aug 25, 2015 01:27 PM
jharrison5
Aug 19, 2015 05:53 PM
