Quicky LS1 swap
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
Re: Quicky LS1 swap
Im on Eibach Ground Control, I didnt cut the bump stops I actually have about 1/4 between the frame and bump stops in the front. Just gotta drive with caution lol
Car: 92 TA vert
Re: Quicky LS1 swap
as for the TV cable its the stock 700r4 and i will post a pic later today of how it attaches
Car: 88 Iroc ls1 swap
Engine: ls1
Transmission: 4l60e
Axle/Gears: original disc
Re: Quicky LS1 swap
thanks that would great ....have a built one was trying to sell it but if i can use it why not...
Car: 92 TA vert
Re: Quicky LS1 swap
Few good reasons not to use the 700
The exhausts clearance I am having now
The ls can not control lock up so you would need to add an aftermarket one
You have to mod the TB for the TV cable
No one make the spacer you will need
Ls computer has alot of control over the 4l60 that you will never have with a 700
Only advantage is
Like mine I bet you have a lot of money into the 700 and is well built
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
