Project OVRMYHD makes 2nd track appearance (and breaks the rear) :(
Old Oct 14, 2012 | 09:39 PM
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
Transmission: 4L60E 3,200 Edge stall
Axle/Gears: 9 bolt w/3.90
Posi went on first run. Here's runs 2 and 3. Hoping to make get her back in time to make one more trip to Tri-state this year. Posi, 3.90's, much cooler air and raised shift points should improve the time a bit
Old Oct 14, 2012 | 10:22 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: Project OVRMYHD makes 2nd track appearance (and breaks the rear) :(
Nice passes,car looks to be hooking pretty good.What have you done for suspension and what are your plans for a new posi..any upgrades lol?
Old Oct 14, 2012 | 10:55 PM
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
Thanks! She should be laying down 60's in the 1.5's though. Qa1's in front, new rear shocks, Spohn adjustable torque arm, Spohn LCA's with relocation brackets, sub-frame connectors. That''s about it for suspension.
Carrier is a rebuild from 9bolt.com. 3.90 gears. All new bearings etc.. T/A performance rear diff cover going on is supposed to eliminate carrier deflection which killed the old unit that had around 260,000 miles on it. From now on I plan on putting her up against the converter some coming off the line instead of flashing it. Hopefully that will keep her together. If not, HELLO s60!
jaridjohn
Jul 8, 2024 03:49 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Irocohio
Aug 12, 2015 08:03 AM
