LT1 Swap - Reading ~15 volts at idle at the battery
Old Oct 18, 2012 | 10:09 AM
cmexlr8's Avatar
Car: 1965 Chevelle SS
Engine: 355
Transmission: TH350
I am worried that my alternator is charging too much. I used the post below to decide how to wire up my alternator:
https://www.thirdgen.org/forums/post...38-post11.html
I have read other threads talking about wiring in a 1 watt 470 ohm resistor to mimic the situation with a 4th gen guage. I am just not sure which way to go. 15 volts is high but not terribly high. The battery is a yellow top optima dry cell mounted in the spare tire well.
Looking for advice.
Old Oct 19, 2012 | 02:10 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Re: LT1 Swap - Reading ~15 volts at idle at the battery
Looking for advice.
I have a one red alt wire and 470ohm resistor and mine charges at 13volts stick a volt meter to your battery to make sure. 15 volts sounds a bit much.
Old Oct 19, 2012 | 02:16 PM
89rs454's Avatar
Car: 1989 SS
After reading this thread you should be fine, http://forums.corvetteforum.com/c4-t...-94-coupe.html
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
