fuel tank, ls1 motor to 86 camaro
so im going to install the ls1 tank to the ls1 motor in a 1986 305 tbi motor car, i heard that this will take the factory fuel line up untill where it goes into the motor, can i just cut the original line use a clamp and connect to a rubber fuel hose to complete the line where it meets the motor? and do the same for the return line? looking for the most economic, fast, safe option.
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Re: fuel tank, ls1 motor to 86 camaro
Rubber hose & the word safe do not belong in the same sentence.
At minimum, get a compression fitting so you can adapt a piece of braided line from the factory steel line to the LS engine.
Here is a compression fitting that converts to AN line.
http://www.summitracing.com/parts/rus-639200/overview/
From here you can make a piece of braided line that will connect to the engine.
thats what i figured...i think i need to talk to summit racing and order the parts for the send and the return line i just dont know if i should cut the line and try to adapt or send a hose from the filter to the motor
Transmission: 4L80E/4L80E
Which factory fuel line are you talking about, the '86, or the LS1?
BTW, there was no TBI in 1986.
you guys think the ls1 lines would fit?
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
15th time, LS1 Factory Fuel lines are not a direct fit, they kick out under the driver, if you replace the line from right where it kicks out to where it straightens back out with one long semi-straight piece of line tucked into the rail it works perfect. So get an LS1 tank with lines off the tank right to just past the filter then add a straight piece all the way up to the rail. Im going this same route with my 67 bird as well.
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
I don't see the advantage of installing the ls1 tank unless you are doing it for smog reasons.
Uhhhh what?? ? Plastic is lighter, rustproof and comes with a built in fuel regulator. Not to mention it has a bucket to eliminate fuel starvation under hard cornering. Cost is usually low too, under the cost of a new pump only upgrade for a crappy 3rd gen tank. Direct bolt in minus extending the filler neck.
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
Face palm.
looks like i have a return line in my 1987i see 2fuel rails that go over thr transmission tunnel from the driverside looped over to the passenger car....i also have a million sensors its weird seems more sensors than the ls1 .....can i just use those two rails one as return and send they are the same diameter?
Is it possible to run an LS1 tank with a new high pressure pump in it. Mount a corvette style regulator/filter where the factory filter is (return back to the tank there) and than run a steel braided 3/8" fuel line from the back of the car along the transmission tunnel to the new LS engine?
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
