L98 to 6.0l LQ9 Swap 89 Iroc
Old Nov 24, 2013 | 06:44 PM
  #51
jtaliaferro's Avatar
Re: L98 to 6.0l LQ9 Swap 89 Iroc
Well I ordered 1 5/8 headers and ended up with this.
these headers fit perfect.... http://www.racinginnovationandsupply...der_p_189.html
And this is slowing any progress down.
Old Nov 24, 2013 | 07:59 PM
  #52
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
I bet the inside dia. is 1 5/8. Dont worry about them not being big enough for n/a. Im still using factory fbody manifolds on my 6.0 cammed with ls6 intake and got 370hp/380tq at the wheels.When I put the longtubes on and a 3 inch y pip with cutouts should be me over 400whp with a retune.
Old Dec 19, 2013 | 01:29 PM
  #53
Well I got some work done on the car.
Dropped the tank and swapped in a Walbro 255 pump, holy crap is that tank not fun to remove or install.
Working on swapping in the PAC valve springs with my homemade spring compressor.
And Finally went to the local pick and pull and snagged a tail shaft with accommodations for the torque arm.
Old Dec 19, 2013 | 02:50 PM
  #54
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Why did you have to swap out the tail shaft?
Old Dec 19, 2013 | 02:57 PM
  #55
Transmission was out of a truck with no provisions for torque arm. I am using the factory tq arm.
Old Dec 19, 2013 | 04:19 PM
  #56
Old Dec 22, 2013 | 12:23 PM
  #57
Well all valve springs have been installed along with rocker arms and valve covers.
TQ arm and drive shaft have been installed.
Old Dec 22, 2013 | 12:29 PM
  #58
Now I have to figure out why the shifting linkage from the 700r4 is not fitting onto the 4l60e. Seems the stud on the 4l60e transmission is to larger to accommodate the linkage from the 700r4.
Never mind I just needed a bigger hammer.
Old Dec 23, 2013 | 10:30 PM
  #59
I decided to use Vbands on my exhaust collectors.
Used some 304 filler and my scratch start tig.
Old Dec 29, 2013 | 02:05 PM
  #60
First start, I still have to finish wiring and ETC.
Old Jan 5, 2014 | 09:23 PM
  #61
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Check here for that linkage: http://www.shiftworks.com/4lx.htm
Do you have the longer stud?
Old Mar 9, 2014 | 03:02 PM
  #62
Idel clip of the TSP 224r
Old Mar 9, 2014 | 05:24 PM
  #63
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Very nice.. Thats my winter project next year
Old Mar 9, 2014 | 05:47 PM
  #64
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
Originally Posted by LastGTA
Nice work. When life happened I sold my 2007 C6 last Spring and picked up my 92 T/A that I'm swapping. From: To:
Hey Dan!
Old Mar 9, 2014 | 11:18 PM
  #65
Engine: 2005 LQ4
Axle/Gears: 3:54
That 224r sounds more aggressive than my 228r lol
Old Mar 26, 2015 | 09:19 PM
  #66
It's been awhile I thought I would update a few things.
Due to ground clearance issues I had to cut up the hawks trans cross member, I am in the process of completing this
once its complete I will snap a few pics if someone is interested.
Car is running pretty well even though I have not drove it all that much. I know after my 1986 lsx turbo z28 this thing is a major dog... LOL
Old Mar 27, 2015 | 08:21 AM
  #67
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
http://youtu.be/_ZjcTUHF9Ck
Sounds healthy
Old Mar 27, 2015 | 11:09 AM
  #68
Originally Posted by IROCgiraffe
Sounds healthy
Thanks....
Here is a short clip of the turbo ls swapped z28.
Old Mar 28, 2015 | 08:56 AM
  #69
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
You must be using 2.5" intermediaries, right? 3" is tough to get around the 4L65e - I know.
From your trans cross-member, it looks like you're going to attach through the side of the rail, correct? I used cylinder collars that go all the way through, then welded on both external sides with the bolts going through them. I also had to scallop the rail a little, but it gave me the clearance needed.
The transbracket pic looks like the one bolt is not tightened flush (it is), the collar protrudes and has weld underneath. The bracket is snug.
Attached Thumbnails L98 to 6.0l LQ9 Swap 89 Iroc-transbracket.jpg   L98 to 6.0l LQ9 Swap 89 Iroc-scallop.jpg   L98 to 6.0l LQ9 Swap 89 Iroc-exfitment.jpg
Old Mar 28, 2015 | 02:57 PM
  #70
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
I made 3" fit, but d*** if its not tight. Burnt 2 shifter cables before putting heat sleeve over the cable.
1984HO
Mar 19, 2021 11:59 AM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
mustangman65_79
Aug 11, 2015 03:17 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
