A 91 RS a 6.0 and some other stuff
Old Feb 26, 2013 | 08:12 PM
  #51
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: A 91 RS a 6.0 and some other stuff
got some parts in today
Unfortunately its not mine ....because I ordered the dominator system with trans control and it will be here in a week or so because im getting alot of extras like gauges boost valves ect Ive been working with the holley system and Its just awsome and you get so much control and save ALOT when compared to buying a boost controller wideband meth controller and two step
Old Feb 26, 2013 | 09:09 PM
  #52
lunati397's Avatar
this is for a turbo montecarlo im building for another guy
Old Mar 8, 2013 | 02:36 PM
  #53
lunati397's Avatar
Just ordered a Holley dominator ECU harness 83 lb injectors low imp and boost solinoids for the boost control doing a duel port setup should have it within a week
Old Mar 12, 2013 | 11:34 AM
  #54
BADNBLK's Avatar
COTM Editor
Sweet build man! You'll have to point it north sometime after you getting it all running.
Old Mar 12, 2013 | 11:37 AM
  #55
lunati397's Avatar
Im getting a 35 ft race trailer that will be going north east south and west this year and one major goal of getting to holley LS fest
the problem is I am just a fuel pump away from having everything I need but I am 3 LS swaps away from even getting to mine
Old Mar 12, 2013 | 11:41 AM
  #56
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
busy man i been wanting to go to ls fest for awhile looks fun
Old Mar 12, 2013 | 11:48 AM
  #57
lunati397's Avatar
this one is almost done
Old Apr 14, 2013 | 09:45 PM
  #58
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
holy cow thats bright
Old Apr 15, 2013 | 01:20 AM
  #59
Engine: 305 to 350
Axle/Gears: 10 Bolt
I like nice
Still trying decided how I want to paint mines such a hard decision , I do know I want blue
Busy guy !!!
Old Apr 15, 2013 | 01:31 AM
  #60
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
i spy with my little eye a lonely blue fitting.
Old Apr 15, 2013 | 10:21 AM
  #61
lunati397's Avatar
its no longer lonely the power steering and trans cooler are all stainless now and it has motor mounts and accy on it now too
I need to get some more pics but for my car parts are rolling in my coil overs came in got a set of MT DRs for the rear 315 35 17 also my ecu and injectors and steel braided line came in for my fuel system
Ive jsut been busy with powdercoating and engine swaps just finished up a 72 chevelle that we put a LS3 in with a tko600 trans and Holley HP ecu I took the SBC headers and got the LS flange and modified them to work and they came out great the passenger side went in first shot the drivers side took about 5 fittings to get it perfect
As soon as this green car is all done ill be putting mine together I plan on doing the motor and engine bay white with some black accents maybe throw a pearl in the white
Old Apr 24, 2013 | 12:03 PM
  #62
lunati397's Avatar
OK back to my car still sitting and waiting but I have alot of parts there for it
l76 truck block (aluminium 6.0 from a vortec max truck)
I got a ls2 pan valley cover
LS3 heads
Holley Hi ram intake with 102 mm tb
lS2 HD timing set
LS9 head gaskets
LS9 Cam (still need to order)
Ky turbo kit TC78 turbo
built 4l80e (stock convertor still but ill get one)
Holley 83 lb injectors
steel braided hose for fuel trans and power steering (hydroboost)
Dirty dingo bracket setup
Holley dominator ECU harness and boost control valves
sump kit to sump the tank
coil overs tubular k member and a arms
SS wheels ( I like them) 315 35 17 MT et streets
just need to get the fuel pump filters and regulator and intercooler and piping
and finish another project before I can work on mine but at least ill have most of the parts together
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
anesthes
Sep 30, 2015 07:48 AM
