92 camaro front mount turbo Ls1 4th gen everything
Old Feb 6, 2013 | 11:53 AM
fbodyman50's Avatar
So I figured it would be a good time for me to start this. I'm building my highschool car. I bought a 98 which I don't really recommend if you are going to be using the factory ecu or fuel tank out of the 4th gen like I am. So far I have the fourth gen dash, console, interior harness, engine harness, brakes, and rear end already done I'm working on the intercooler and turbo piping currently. I'm definitely stoked to get it running! Ill try to post some pictures up of it soon.
Old Feb 7, 2013 | 10:44 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: 92 camaro front mount turbo Ls1 4th gen everything
Dont worry about the 98 stuff. If your planning on keeping it which by the sounds of it you are, the system will work just fine and you can run your stock third gen tank if its in good shape to save the fuel gauge sender hassle anyways. The engines are good too but a rod bolt swap and a new oil pump are mandatory if not already done. Have fun wrenching
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
reiderz iroc
Aug 13, 2015 04:57 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
