Best stock lt1 for thirdgens
Subscribe
Feb 18, 2013 | 06:04 PM
  #51
Re: Best stock lt1 for thirdgens
So me having a tbi I'm gonna have to replace it?
Reply 0
Feb 18, 2013 | 09:37 PM
  #52
Probably. Dropping the tank is not that hard, just time consuming. Or you can install an in-line pump. Havent heard a bad thing about them yet
Reply 0
Feb 18, 2013 | 10:14 PM
  #53
Quote: Probably. Dropping the tank is not that hard, just time consuming. Or you can install an in-line pump. Havent heard a bad thing about them yet
Its what my mechanic has to do and I gotta pay for. Never heard of a inline pump
Reply 0
Feb 19, 2013 | 07:22 AM
  #54
it is how it sounds. it just splices into the fuel line incase you dont wanna drop the tank
Reply 0
Feb 26, 2013 | 09:34 PM
  #55
Haven't got that far. Looking for a part at autozone to connect the lt1 fuel rails to my thirdgen, where to put the o2 sensors
Reply 0
Feb 26, 2013 | 09:49 PM
  #56
Quote: Haven't got that far. Looking for a part at autozone to connect the lt1 fuel rails to my thirdgen, where to put the o2 sensors
Pn# is listed in the stickies. I use a quick disconnect to -an6.
Reply 0
Feb 26, 2013 | 10:53 PM
  #57
Quote: Pn# is listed in the stickies. I use a quick disconnect to -an6.
Thanks, hopefully my mechanic can get it
Reply 0
Mar 31, 2013 | 01:40 AM
  #58
Update.
Ditched the stock 93 alt grabbed an 95 alt
All leaks sealed and so far so good.
Reply 0
Aug 29, 2013 | 11:51 PM
  #59
Update
If you put a 95 alt on a 93 you will have a battery drain because the wire on a 93 regulator is a constant. Took it to the electric automotive shop put a internal self regulator in it for $100. Works great.
Had to upgrade my o2s to heated like the 94-95. And the 93 have smaller injectors, that's all the other stock lt1s have that I found different.
Reply 0
Subscribe
