Lt1 swap in progress have need advice
Old Feb 14, 2013 | 10:44 PM
usmcfirebird92's Avatar
Car: 1989 GTA Trans Am
Engine: 5.7 Tpi Soon to be LT1
Axle/Gears: ?
The junkyard lt1 is coming along well but I have this idea and wanted to throw it out to see some responses. I'm trying to mount the alternator low (on an fbody bracket) in order to attempt to use the stock ac compressor. Why? Because the compressor and lines are new and fresh serviced. Also would like to bypass the crossmember replacement/modification. But was wondering about possible clearance issues. The car is in paint and I can't mock it up also can't mock the ac compressor up top the mount. I have seen it done. But just my opinion the alternator sticks out pretty far.
Old Feb 14, 2013 | 10:48 PM
Axle/Gears: ?
Re: Lt1 swap in progress have need advice
Trying to post more pictures.
Old Feb 14, 2013 | 10:49 PM
Axle/Gears: ?
Here's one from another angle.
Old Feb 15, 2013 | 08:07 AM
Pocket's Avatar
Car: 91 Trans Am
Looks like it would hit the pass frame rail
Best fit would be to make your own accy bracket, its not hard or expensive
Old Feb 15, 2013 | 09:32 AM
Axle/Gears: ?
Ill look at doing that and I guess I could always use the third gen alternator it's so much smaller.
Old Feb 15, 2013 | 11:00 AM
Pocket's Avatar
Car: 91 Trans Am
And puts out less. If your car is fine with that, then go for it
Personally, Id build custom accessory plates rather than re-engineer an existing bracket
Old Feb 16, 2013 | 06:46 AM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Or notch your Kmember and get new ac lines. Save alot of time and hastle re-designing it
Old Feb 16, 2013 | 07:19 AM
Firebat's Avatar
The LT1 alt is very big. May have more luck with a smaller style CS130 alt, smaller LT1 alt (L99) alt, or other smaller alt. Here is a link just to throw some ideas out there:
http://ls1tech.com/forums/lt1-lt4-mo...ve-covers.html
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Hello, Michael
Aug 20, 2015 03:19 PM
sreZ28
Aug 14, 2015 07:48 PM
