ltx a/c pulley question
Old Mar 4, 2013 | 03:08 PM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
I am swapping an 97 LT1 into an 84 Z28. I am using a 94 serpentine setup w/ a/c delete pulley. This one is a bit technical for me. I am putting the BBK crank underpulley on the serpentine and already have the shorter belt. I want to keep my a/c (I live in south texas and this is my daily driver). Can I use a bracket from a corvette or something else on the drivers side to mount my a/c. Remember with that BBK crank underpulley, the harmonic balancer will not have a belt on it. I am hoping that I can use a bracket from some other car and probably a spacer or two (on the bracket) to make the harmonic balancer act as a pulley for just the a/c compressor. Any thoughts? Am I reinventing the wheel?
Old Mar 4, 2013 | 06:03 PM
jaybdaboat's Avatar
Car: 1987 Sports coupe/z28
Engine: 2.8/ swapping 5.3
Axle/Gears: Open 3.42
Re: ltx a/c pulley question
You got a pulley for a/c delete, but want to fab it to use a/c?
Old Mar 4, 2013 | 06:11 PM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
There are a couple of ways to do it.
The first is to notch the subframe to fit the F-fody LT1 compressor. Then have a set of A/C hoses made to connect to the stuff on your car.
https://www.thirdgen.org/forums/ltx-...lt1-build.html
look at post 32 35 and 70. those pictures will give you an idea of what needs to done. I did cut and weld an actual notch into the subframe to better. the lines might not clear the headers.
The next is relocation bracket. here's the link http://www.bowersrodshop.com/index.p...pper&Itemid=60
The last is use all the corvette LT1 accessories.
check the LT1 swap faqs it'll give more if you need it
Old Mar 5, 2013 | 06:46 AM
Car: 1984 Z28 T-TOP
No, I want to use the delete pulley for ease of installation and don't want to notch the k member. So I want to try to try to use the harmonic balancer. To run a second belt
Car: 1984 Z28 T-TOP
Thanks diablizzard, I may need to use the relocation bracket
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
Navy8125
Aug 22, 2015 07:13 PM
redmaroz
Aug 16, 2015 11:40 PM
