Turbo 4.8 Help
Old Mar 31, 2013 | 06:47 PM
AssaulT/A's Avatar
Car: 1986 Trans Am
Axle/Gears: 3.08? unlimited slip
Turbo 4.8 Help
About what level of compression will 243 heads give me on a stock bottom end 4.8? Planning for a "budget"-ish turbo build soon, shooting for maybe 15 psi? I've seen several 243 heads on 5.3 builds, but none that i can recall on a 4.8.
Old Mar 31, 2013 | 07:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Turbo 4.8 Help
Some newer 4.8's come with 243's and they were 9-9.2 to 1.
Older heads were around 61cc and 9.5 to 1 comp while 243's should be 64-65cc. So comp should be lower
As long as you are at or under 10 to 1 and looking for moderate power, it will love boost.
Old Apr 1, 2013 | 05:43 PM
AssaulT/A's Avatar
Car: 1986 Trans Am
Re: Turbo 4.8 Help
Excellent! that sounds just about perfect. Thanks!
Old Apr 1, 2013 | 09:09 PM
AssaulT/A's Avatar
Car: 1986 Trans Am
Re: Turbo 4.8 Help
I also heard that some model year 4.8's are stronger? Is there any truth to this?
Old Apr 1, 2013 | 09:41 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Turbo 4.8 Help
Some had weaker rods than others. I am not sure of the year but i think 06-07 up maybe? Even so a weak rod motor with arp bolts can still hold big hp. My buddy/tuner is goin on 3 yrs with a weak rod 5.3 thats up in the 700whp range in a silverado
84LsxZ28
May 17, 2020 02:21 PM
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
New2Chevy
Sep 28, 2015 12:35 AM
