Exedy clutch anybody use one?
Old Apr 1, 2013 | 06:03 PM
subedriver's Avatar
In the process of my ls1/t56 swap and was wanting to do a new clutch/flywheel/slave cylinder while I had everything out. saw this on ebay
http://www.ebay.com/itm/EXEDY-CLUTCH-KIT-SLAVE-FLYWHEEL-CAMARO-Z28-SS-FIREBIRD-FORMULA-TRANS-AM-5-7L-LS1-/160999725107?pt=Motors_Car_Truck_Parts_Accessories&hash=item257c54d833&vxp=mtrAnybody have any experience with these?
Trying to keep my swap as cheap as possible right now, so I'm not looking to spend $800 or better for a clutch kit. If I have to, I have to but would rather spend that money on something else. Ls1 will be ran stock for quite a while, until I can really build it.
Old Apr 1, 2013 | 06:40 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
Re: Exedy clutch anybody use one?
Never heard any first hand experience with them. Just a FYI though, a complete ls7 clutch setup with flywheel can be had for around 500, minus slave cylinder. Good for 600HP, smooth as stock.
Old Apr 1, 2013 | 07:14 PM
subedriver's Avatar
is there a certain brand you would suggest for that? looking on ebay there are several different ones
Old Apr 1, 2013 | 07:20 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Most others and I buy GM kits ( made for the OEM by LUK). If your not in a hurry, just keep an eye on eBay, most of the time you can get one for around 500, I actually scored a disc, plate, and flywheel for 375.
Old Apr 1, 2013 | 08:06 PM
subedriver's Avatar
so theres this one
http://www.ebay.com/itm/LUK-CLUTCH-KIT-SLAVE-FLYWHEEL-1998-2002-CAMARO-Z28-SS-FIREBIRD-FORMULA-5-7L-LS1-/400451641137?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d3cc71f31&vxp=mtrthat says its for a ls1 and will fit
or this one
http://www.ebay.com/itm/LUK-CLUTCH-KIT-SLAVE-RACING-FLYWHEEL-CORVETTE-C6-6-0L-LS2-6-2L-LS3-Z06-7-0L-LS7-/160987396384?pt=Motors_Car_Truck_Parts_Accessories&hash=item257b98b920&vxp=mtrthat one says it fits corvette only, but pretty sure the clutch measurements are the same. is it really worth the extra $200?
Old Apr 1, 2013 | 08:16 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
The first one is a standard ls1 kit by the looks of it. The second one is more due to the SFI approved lightweight flywheel. Good upgrade IF the manufacturer is a good one.(I just never had any experience with exedy parts).
These are the OEM kits that are generally referred to: http://item.mobileweb.ebay.com/viewi...id=53325726971
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
