weak spark on 2 cylinders lt1
Old Apr 21, 2013 | 09:18 AM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
first fire up was this week. yesterday i got.my y pipe hooked up and it sounded great came.back out awhile later and i notice on its next.fire.up it was running.rough. i found two cylinders had a weak spark compared to another spark plug i pulled out. am i looking at getting a new.opti or else?
Old Apr 21, 2013 | 10:09 AM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: weak spark on 2 cylinders lt1
Check resistance in your plug wires, or you can switch plug wires to see if the problem stays with the wire or spark plug.
Id also re-check the plug gap.
Old Apr 21, 2013 | 12:35 PM
jaysfs's Avatar
Transmission: t56
Maybe.the.plugs.sucks they are new
Old Apr 25, 2013 | 07:50 AM
jaysfs's Avatar
Transmission: t56
Ok so i have moved around my spark plugs and spark plug wires moved my injectors and changed even my opti out to still have the same problem. this lt 1 is about to be thrown out and a 383 carb go in
Old Apr 27, 2013 | 02:48 PM
jaysfs's Avatar
Transmission: t56
I got a code p1361 low voltage to control module.anyone get that and what was the fix? i just ordered a new msd coil.do i need a new icm? anyone?
db057
Apr 28, 2019 07:45 AM
MM2Robinson
Oct 1, 2017 09:16 AM
L0tuS
Oct 4, 2015 08:07 AM
camarohelp
Sep 22, 2015 03:19 PM
L0tuS
Sep 4, 2015 11:16 PM
