LT1 accessories bracket
Old May 19, 2013 | 09:36 AM
gm muscle's Avatar
Car: '89 Iroc-Z
Engine: 5.7 TPI
Transmission: 700 R4
Axle/Gears: 2.77
I am looking at starting my LT1/4l60e swap in an '87 Monte SS. I've read plenty about the possibility of having to notch the frame in order to clear the AC compressor.
I also read that getting the accessories bracket from an LT1 Corvette would be the way to go without messing with the frame.
Now for the questions:
1) Are the accessories interchangeable between Camaro and Corvette?
2) Should I just have the frame notched and be done with it? (if it needs it, of course)
Old May 19, 2013 | 08:01 PM
Strick1's Avatar
Car: 92 Vette, 83 Camaro
Engine: 305 going to 95 LT1
Transmission: 5 speed going to T56 6 speed
Axle/Gears: 3.73 posi with disc brakes
Re: LT1 accessories bracket
I'm doing a swap too. I chose to use the 92-96 C4 Corvette AC Alt accessary set up. I bought a complete setup off the internet. Cost was around $800. It had everything,brackets, bolts, pulleys, AC compressor, Alt, etc. Once you're down to the bare front of the LT1 all the pieces, brackets and all just bolt right on. I'm lucky as I own a 92 Vette that uses this same set up and I use it to see where all the parts go. To me it is a cleaner set up and replacing the AC compressor is so much easier.
This is what you need
Old May 23, 2013 | 10:53 PM
88monteSS's Avatar
Car: 92 RS/97 K3500/07 ISS
Engine: LT1/454/LS4
Transmission: 4L60E/4L80E/4T65E-HD
Axle/Gears: 2.73/4.10/3.29
If you're set on not notching the crossmember (not going to get into that debate lol) and you already have f-body/b-body accessories, you could get a bracket kit that relocates the compressor you already have to the top left of the motor, should put it pretty close to where the stock monte compressor was. I can't recall off hand where I got mine, but if you're interested I can check next time I'm in the shop, IIRC it was <$300 for the kit.
88SS6SPEED
Nov 11, 2015 07:05 AM
codeysabatini
Nov 10, 2015 04:07 PM
BDR
Nov 7, 2015 03:05 PM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
