04 tahoe harness and ECM - Can I use?
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
So I've hit a roadblock on my swap, well, somewhat of one. I have a 2004 5.3L LM7 that I'm installing into my 89 IROC. The tahoe uses a drive by wire throttle body, which I do not want to fool with. Having said that, is it possible, if I run an LS1 intake and cable driven throttle body, to still use the ECM and harness from the Tahoe?
I guess what I'm getting at is can it be tuned out of the computer or reflashed? I know I'll have to change the fuel injector wires over to the LS1 connectors but is there anything else I should be concerned with? I'm running the C5 vette accesssories on the motor as well.
Trying to do this on a budget, combine my stock L-98 harness with the truck harness myself. If its not possible then I'll buy a reworked LS1 harness and computer. Just wanted some opinions from some of you experienced swappers. Thanks
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 04 tahoe harness and ECM - Can I use?
he may run into an issue with the pcm though, no? I thought some of the new models don't have the drivers necessary for the iac?
Maybe, but a $30 replacement PCM is a small item compared to the job of rewiring the harness
Heres a quick pass/fail for the PCM being compatible with DBC TBs
http://www.lt1swap.com/cable_conversion.htm
Billy Decker
Sep 4, 2015 03:46 PM
