Estimated HP roughly?
Old May 24, 2013 | 06:57 PM
Boreen's Avatar
I was wondering if anyone can really estimate my power range? I know there is a ton of variables to get a true close estimate, but maybe someone on here has run a similar set up.
I am runnin an LS3 with an aggressive cam (custom grind, will get exact specs soon) , I think it's got mid .600's of lift tho (.640-.660 area). Not sure on duration exactly. Valve springs are also done with double beehives I believe (again, will have to confirm with my engine builder), aggressive idle tho.
1 3/4 primary headers, 3" y-pipe, 3" SLP loudmouth exhaust
GMPP wiring harness/ECM (still need it custom tuned by someone for most hp/Tq possible)
Stock Ls3 intake from vette, stock 90mm throttle body. 4" Cold Air Intake piping with big filter.
Might go with Underdrive Pulleys, not sure yet. Are they worth it entirely?
LS7 clutch and flywheel, ls1 T56 (low mileage), ls1 aluminum driveshaft, ls1 rear diff with limited slip and 3:42 gearing. 18" C6 Z06 wheels with 245/40/18 tires.
Also, while I'm asking, how much lighter is this engine/trans combo compared to a iron 355 with cast vortex heads that's carb'd. No AC on either engine.
Thanks in advance guys.
Just wanting to get a rough estimate until I can get it dyno'd somewhere.
Old May 26, 2013 | 10:14 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: Estimated HP roughly?
I wouldnt be surprised if it hits north 425rwhp..465 on the high side depending on head work.Should be a nice setup street/strip
Old May 26, 2013 | 10:38 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
incoming broken driveshaft and/or rear-end..
Old May 27, 2013 | 02:14 AM
Boreen's Avatar
I'm not out to race my car or bag drive it so I won't be dumpin the clutch outta the hole. I wanna try and make this diff, driveshaft and clutch last for a few years until I build the engine at least.
425rwhp? I thought the newer camaro/vettes had 425rwhp from factory with these engines?
What's it take to hit closer to the 500rwhp mark without some spray or FI?
Old May 27, 2013 | 11:52 AM
my88transam's Avatar
Car: 1988 Trans am
Engine: 305 TPI, LS1 in progress
Transmission: T-5, MN12(GTO T56) in progress
Axle/Gears: 10-bolt/308
Newer LS3 camaro and vettes are "rated" at 426 hp at the crank for the camaro, and 430 hp at the crank for the LS3 vette. So about 370 rwhp through a 6 speed, roughly obviously. Knowing the exact specs of your cam would help, along with other mods such as work to the cylinder heads would be helpful. An ls3 with cnc ported heads, a cam that works well with the heads in the 230's duration range, and free flowing exhaust, not sure if a 3" single is optimal but I'm sure it's been done, and obviously a great tune could get you in the neighborhood of 500 rwhp with UD pulleys, the 6 speed, and light weight 10 bolt rear end. However, I'm not sure about cams for ls3 heads, they can be a little sensitive and often times guys make better power with cams that have a little less lift. So i have read, don't quote me on that.
Old May 28, 2013 | 08:31 AM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
you need to remember that anything the general, ford, or those mopar guys advertise is at the crank, not on the ground.
you should knock down 425+ at the wheels with a good tuner. too much cam will make the car lazy down low, but you'll have brutal top end power.
Old May 30, 2013 | 11:36 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
He should be well north of 425. Mines a mild combo compared to his and I'm there already with an automatic.
Reid Fleming
Oct 10, 2015 09:56 PM
drumstixer
Sep 29, 2015 03:02 PM
Jlanz55
Sep 29, 2015 08:55 AM
amcnellis
Sep 16, 2015 04:16 PM
ULTM8Z
Sep 16, 2015 09:15 AM
