Need help, Engine swap, LS1 into a 92 camaro
Old Jun 11, 2013 | 11:33 PM
john_rs25th's Avatar
Car: 1992 RS 25th anniversary
Engine: 5.0
Transmission: 700
Axle/Gears: 99 Z28 rear axle 3.23
Hi, I need help, Im goin to make an engine swap, but I have a doubt, how do I know if the ECM is from a Z28, does the ecm have a number or something, I also got the engine and trans for only 800 dlls, it only have about 32000 miles, I know that I need to change the motor mounts, and the trans support, but the doubt is about the ecm, thanks for you help.
Old Jun 11, 2013 | 11:44 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: Need help, Engine swap, LS1 into a 92 camaro
If its a :
98: 16238212
99-02: 9354896 , 12200411
Old Jun 12, 2013 | 04:02 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If the LS is the same as a LT1 engine then all cars in a given year got the same part # PCM ;
http://chevythunder.com/LS1%20compon...Identification
It was the factory calibration (tune ) inside a PCM that determined what car it was intended for ; so you can get any tune you wish flashed ( loaded ) onto a LSX PCM
Wealth of swap info in the LSX Dept
https://www.thirdgen.org/forums/ltx-...third-gen.html
Old Jun 19, 2013 | 05:00 PM
Pocket's Avatar
Car: 91 Trans Am
Originally Posted by Z28ricer
If its a :
98: 16238212
You'll find the ID on the PCM sticker under service number. If its the 98 version, I highly recommend buying a 99-04 PCM and repinning the harness to match
Old Jun 19, 2013 | 10:21 PM
Engine: 5.0
Transmission: 700
thanks, why is better the 99-04 ecm, it has more HP, or what, I really don't know too many things, that is wy I ask all, thanks for all.
Old Jun 19, 2013 | 10:24 PM
Engine: 5.0
Transmission: 700
why is better the 99-04 pcm, it has more HP's or what, I don't really know too much things, that's why i ask for all, thamks for your help.
Old Jun 19, 2013 | 10:27 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Wish I had known this when i was doing my swap. running into pcm fun now..............
Old Jun 19, 2013 | 10:28 PM
V6canvas's Avatar
Engine: Stock LS1
the 99 and newer pcms have better processors, basically, it's a faster/updated chip
Old Jun 20, 2013 | 04:24 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
I will give you ONE idea of why it is better. After I finished my swap we went for a drive to tune it. My tuner would start with a basic tune to get close and then we take off. We would get a few miles down the road and notice some things that needed to be modified. I would have to pull over and shut the car off, turn the key on and sit there for 45-50 seconds to flash the computer. Then shut the key off and then start again with the drive. Then needed to change more info so here we go again with the pulling over ,shutting it off and waiting for the flash. Pain in the butt! My tuner told me that the 99-up computers can be flashed on the fly! Hence, not all the starting and stopping. He also said that if I were ever going to run a turbo or supercharger that I would need the newer computer to be able to handle it. the newer computer has and uses much more data. Therefore can be manipulated or tuned if you will better because there is more info to play with. kinda like the difference between a 1985 Apple 2E vs A new Mac book pro... No comparison.
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
theshackle
Mar 5, 2017 06:37 PM
reiderz iroc
Aug 13, 2015 04:57 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
