Operation wet dream it's becoming a reality
Old Jul 15, 2013 | 11:07 PM
Kurtis2short's Avatar
I have an 88 firebird I've own since I have 17 after 4 small blocks I have a 427 big block in it which was just a straight line monster but sadly there's a replacement for displacement technology. So not only do I wanna go in a straight line but hug the corners. So here comes the fun. I'm build a 396 striker with a t6 s475 Borg with a billet compressor wheel. Run down I have a ly6 iron block 6.0 bored .30 over the crank is a forged 3.90 eagle crank and h-beam 6.125 rods with a set of custom made weisco pistons coated top and side. I will be tapping the block for some oil squirted from blp. The heads are a set of procomp ls3 2.20 custom made Manley valves and 1.6 intake both stainless with brain tooley .650 springs and a comps ungraded on the ls3 rockers. A custom grind cam from tick performance. Being feed by a Holley hi ram 102 mm intake a Holleys 120 lb injectors. The cam I should b shifting at 7400 rpms and 1000 rwhp is my goal. I know I don't have to spin a turbo lax motor to 7500 with a turbo over kill maybe but it should sound like Thor dropping the hammer. To hold all of that every piece of suspension is being swapped with umi and founders. A 5th gen brake up grade thanks to fly bye for that and a built 10 bolt from a 02 Camaro aftermarket eaton posi stock with 3.42 gears kegs axle upgrade kit welded the tubes and a cover. The shocks are Vikings adjustable and the fronts will be switched out the day they go on sale for the fronts .
Old Jul 15, 2013 | 11:28 PM
Re: Operation wet dream it's becoming a reality
Pics
Old Jul 15, 2013 | 11:31 PM
Pic
Old Jul 15, 2013 | 11:40 PM
Pic apparently I'm having problems loading up pics but I also will be running a viper srt10 t56 that the main shaft has been cut done also the front put shaft has as well and the mid plate and rear has been changed
Old Jul 16, 2013 | 12:25 AM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Subscribed!!!!
Old Jul 16, 2013 | 02:47 AM
I'm have bill at bp wiring http://www.bp-automotive.com/site/c2...s__2.html#2988 do all my harness to work with the stock gauges I know motors and body work but wiring ill leave that to him
Old Jul 16, 2013 | 10:18 AM
Wiring is usually a pita lol
Old Jul 16, 2013 | 11:47 AM
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Might want to rethink the 10 bolt on such a nice build.
Old Jul 16, 2013 | 12:29 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
I wouldnt run a built 10-bolt behind something like this. Could it hold up...maybe. But for everything you're putting into this, a beefier rear would be nice to see!
This should be a good build! Cant wait to see your progress!
J.
Old Jul 16, 2013 | 05:20 PM
Later down the road ill probably do a 9 inch swap this is just a rear end I had laying around out of my 02 so I figured why not
Old Jul 17, 2013 | 10:24 AM
Car: 86 Trans AM
Because having it grenade on the highway stinks and now is the time to upgrade!! haha. You're going beefy on everything else.
Totally understand though. We're just trying to twist your wallet for you
J.
Old Jul 17, 2013 | 11:24 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
J.
I ended up in the same situation with my swap, way over-powered for a ten bolt. Its upgraded as much as a ten bolt can be, but I now find my driving habits center around not exploding the diff, instead of ripping gears the way I'd like to. Hopefully the rear holds so I can re-group some of its cost by selling it when I upgrade rear diffs again.
Old Jul 22, 2013 | 09:56 PM
I've had a few 10 bolts into the 9s behind some big blocks they really are hit or miss. This weekend before it started raining in I got the brakes hooked up. I'm using a 4th gen booster and the res with a after market cop proportioning valve and my steering shaft upgrade
Old Jul 22, 2013 | 10:03 PM
The astro van upgrade its just a clean look
Old Jul 22, 2013 | 10:19 PM
Pic
Old Aug 5, 2013 | 02:37 PM
My bp wiring came in today and wow I'm impressed. He took my old wiring harness and retro fitted it for the lsx and I'm still like damn. All plug and play is nice.
Old Aug 5, 2013 | 02:39 PM
Another
Old Sep 3, 2013 | 09:50 PM
Loaded up to head to the frame shop. Over the years of abuse there are stress cracks so I'm gonna have it straighten and have them weld my connectors in when in the machine. Probably over doing it but I ding plan on ever selling it so over building it.
Old Nov 26, 2013 | 03:23 AM
I got my heads together I'll have my short block out together over the weekend. It does look like much but u have the 2.20 1.6 ls3 heads next to my 2.02 1.6 heads pretty but difference
Old Feb 20, 2014 | 03:24 AM
Finally got my top back from being polished and ported the inside to match on the runners
Old Feb 20, 2014 | 03:26 AM
This is it a little eye candy
Old Feb 20, 2014 | 11:26 AM
krazeefewl's Avatar
Car: 1991 Camaro RS
Engine: 305 will be LSX eventually
Axle/Gears: Borg Warner
That things looks really good polished
Old Feb 21, 2014 | 06:49 PM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
They sure did a nice job of that wiring harness. All new wire too?
That intake is SWEET!
Old Feb 21, 2014 | 08:59 PM
Ya the gent at bp really did a great job with the harness set him my old cut up v6 harness and cut it all and replaced all the wiring so I can use all the factory gauges. I think it'll be a clean factory look. You think holley would offer a polished or chrome hi ram cause I think it looks amazing
Old Feb 22, 2014 | 10:39 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Nice build. 9's???? I have no idea how you guys are getting some of these numbers out of a stock diff I blew up so many with stock 305's on 245 street tires etc. I guess I drive em a bit too hard maybe
Old Apr 29, 2014 | 03:42 AM
Sorry on the delay on things works been crazy. I got the long block together moral 5290 link bar liters arp head studs and ls9 gaskets with a hv melling oil pump that I ported.
Old Apr 29, 2014 | 03:43 AM
Halfway
Old Apr 29, 2014 | 03:49 AM
Another
Old Apr 29, 2014 | 03:50 AM
With the heads torqued down
Old Apr 29, 2014 | 03:52 AM
The intake port gives yea an idea of these bad boys
Old May 2, 2014 | 03:03 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Man this is gonna be a beast. I'm watching this one for sure.
Old May 2, 2014 | 04:49 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Subscribed! Looking good so far! and only teases
Old Jun 1, 2014 | 10:53 PM
Got everything together forgot to take a pic of the improved racing oil baffle and cleaned up the oil pan around the filter for better flow.
Old Jun 1, 2014 | 10:54 PM
Assembled
Old Jun 1, 2014 | 10:55 PM
Improved racing
Old Jun 17, 2014 | 04:15 AM
Got the intake on
Old Jun 17, 2014 | 11:53 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Following this one! Lookin good!
Jay
Old Sep 25, 2014 | 11:14 PM
Sorry guys got side reacted getting my k5 painted up before winter the motor is complete
Old Sep 25, 2014 | 11:29 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Looks great!
Old Sep 25, 2014 | 11:57 PM
Thanks too much money in it the holley polished covers were a pretty penny
Fanatic1074
Oct 3, 2022 05:57 AM
darwinprice
17
Oct 11, 2015 11:51 PM
Royal_Z
Sep 30, 2015 08:45 PM
Formula8r89
Sep 22, 2015 04:24 PM
