92 RS 3.1L to a 5.7L LT1
Old Jul 22, 2013 | 06:47 PM
VictorWeirich's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: LS3
hey guys I'm new to this forum and i was hoping some of you guys can help me, I have a 1992 Camaro RS with the 3.1L V6 and BW T5 tranny, my engine recently took a huge dump hahahahaha, anyways, i purchase a LT1 out of a 94 z28, harness and ecu.... problem was the t56 was destroyed...i already figure out the wiring problems so far, I think, but in my attempt to use my T5 i notice my input shaft is different, the clutch plate is bigger, I already bought a V8 bell housing my question is, what do i do about the input shaft? any help relataded to the swap is much appreciated
Old Jul 23, 2013 | 12:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can use a clutch disk for the 4.3 S10 application. It will have the proper splines for the input shaft, and mostly match the 3rd gen V8 pressure plate.
But, you'd better not drive this thing any harder than you drove the V6. The input shaft is smaller, and the 1st gear a higher ratio - smaller shaft means weaker, higher ratio means more stress on the case.
Old Jul 23, 2013 | 03:13 PM
Engine: LS3
Re: 92 RS 3.1L to a 5.7L LT1
thanks!! I also came around 2 T5 with 26 spline input shafts, one was out of a 305 camaro and the other one was out of a 5.0 mustang, can i use them? and if so which one is better?
Old Jul 23, 2013 | 03:53 PM
five7kid's Avatar
I've just about exhausted my complete encyclopedia of T5 knowledge, but as I understand, the 'Stang T5 doesn't sit right in a 3rd gen. But, the Camaro one should bolt in.
Old Jul 24, 2013 | 01:30 AM
Engine: LS3
so anybody has done the harness conversion?
i should say combine the c100 bulkhead connector from the 3rd gen with the 94 lt1 harness?
Old Jul 24, 2013 | 08:05 AM
krazeefewl's Avatar
Car: 1991 Camaro RS
Engine: 305 will be LSX eventually
Axle/Gears: Borg Warner
five7kid is right about the Camaro T5 will bolt right in, but the housing on the mustang is different than the Camaro. I'm not exactly sure on how they are different, if I remember correctly the tailhousing is what makes it not a direct bolt on for our cars. I'm pretty sure that the LT1 has more power than what the T5 is rated for so if you're looking to buy a different trans. I would look into a T56. Yes it costs a considerable amount more, but you will actually be able to have fun with the car and not worrying about blowing the trans.
88SS6SPEED
Nov 11, 2015 07:05 AM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 4, 2015 07:48 PM
WejaZ28
Oct 3, 2015 07:38 PM
bjpotter
Oct 2, 2015 09:12 AM
