wiring harness
Car: 92camaro,86 camaro
Engine: 355
wiring harness
i have a 2001 chevy truck with a 4.8 engine that im pulling to put in my camaro so my questions is can i pull the wiring harness inside the cab dash to run it in my camaro?
Transmission: 4L80E/4L80E
I have no idea what the cluster looks like, so can't say if it would mount in your 3rd gen dash.
The gas gauge won't be compatible with your 3rd gen sensor. The signal comes from the PCM, and the truck uses a different resistance range sender.
Other than that, assuming you can get it mounted somehow, it should work.
Engine: 355
Re: wiring harness
im going to some how to put the cluster in the camaro. and does the 4 gen camaro fuel pump ohms same as silverado?
