Converted TPI/LT1 problems
Old Sep 6, 2013 | 02:03 PM
mojo_jojoe4's Avatar
Car: 1991 Firebird Vert
Engine: 383 L98/LT-1
First off, my timing is way too high, it's jumping off the marks, and I try to turn the distributor, but I can only turn it so much and it hits the back of the intake where the bolt is on the distributor.
Second, I replaced the fuel pressure regulator and the fuel pump, and it's still above 90PSI. Is there a way to figure out what the problem is before I swap out all of the fuel lines?
Old Sep 6, 2013 | 02:12 PM
Re: Converted TPI/LT1 problems
The fuel pump I replaced was the Granetelli 255LPH from Jegs, and the FPR was one they found that had the bracket on the correct side for my mounting purposes was for a Buick Rendevous.
Old Sep 6, 2013 | 04:21 PM
Pocket's Avatar
Car: 91 Trans Am
Jump a tooth or two on the dist and set the timing again. It doesn't necessarily have to point at #1 TDC to run, only the orientation between rotor and points is important
What regulator are you running? When I did the lt1 intake conversion, I was forced to use a SLP AFPR for space and even that had to be turned around
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Mar 5, 2017 06:37 PM
69 Six Pack
Oct 5, 2015 07:51 PM
dyeager535
Aug 28, 2015 08:10 AM
gta power
Aug 13, 2015 06:15 AM
