Am I the only guy who has a carbed Lt1???
Old Sep 11, 2013 | 09:53 PM
1qk4mula's Avatar
Car: 91' Formula/88' Formula
Engine: 5.7L TPI/ 5.7 zz4 with mini ram
Transmission: 700r4/Stock T5
Axle/Gears: 10 bolt 3.23 /9 bolt 3.70
I have an LT1 converted to carb in my 87 Trans am...
How do you run the accessories???
I can't use the LT1 serpentine system cause I'm running the gen1 balancer and pulley..
I can't use the 88 and up serpentine system cause the LT1 water pump...
I want to use 87 and older alternator and pump? Has anyone done this??
Old Sep 12, 2013 | 12:53 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Am I the only guy who has a carbed Lt1???
put an LT1 hub and balancer on it and run LT1 accessories.
Old Sep 12, 2013 | 05:45 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
It is pretty well accepted you have to run the LT1 only front access drive on a LT1 unless you are into custom fabrication
Old Sep 12, 2013 | 05:52 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
the LT1 water pump...I want to use 87 and older alternator and pump?
Do you understand how the coolant system works on a LT1 ?
Have you actually had a look at what you own , compared the pump and block difference between a GEN I and a GEN II (LT1 ) engine ???
A regular SBC has coolant port on each side of the block for the pump , the LT1 has 2 ;
how did you plan to get around that little problem 1st?
Old Sep 12, 2013 | 07:19 AM
1qk4mula's Avatar
I can't use the Lt1 hub...I'm running a carb with distributor on top. I have the front plug that covers where the opti spark used to be.. And only the gen 1 balancer fits on there now.
I also can't use the lt1 accessories cause that system sits further back and I would have to cut my aluminum valve covers to clear the alternator..
I have and want to use my 87 power steering pump and alternator, I was wondering if anyone has done this and if they had pics of it..
Old Sep 12, 2013 | 07:27 AM
1qk4mula's Avatar
Sorry you mis understood, I'm using the Lt1 water pump, it's the power steering pump and alternator that I have to install..
The lt1 water pump is slightly in the way of the v belt for the power steering pump. I know it's possible, just wondering if anyone has done it yet and if they had pics they could share.. Thx
Old Sep 12, 2013 | 07:29 AM
1qk4mula's Avatar
Understandable.. Anybody who's done this before have any pics?
Old Sep 18, 2013 | 05:08 PM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
look for the username z28metalhead he's gotta lt1 with a carb. if that helps
Old Sep 18, 2013 | 06:50 PM
Pocket's Avatar
Car: 91 Trans Am
Grab some lexan and fab a new bracket. The is no off the shelf or simple mod bracket that will fit the lt1
Mix and match accessories only works on SBCs
Old Sep 20, 2013 | 05:33 PM
Car: '90 Camaro
Engine: 305 tbi
found this just now and thought of this question..
Old Sep 20, 2013 | 05:38 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Use the LT1 accessories and low mount your alternator so you don't have to modify your valve cover. There is a write upon this site on how to do it.
Old Sep 20, 2013 | 06:53 PM
1qk4mula's Avatar
Thanks diabolicalRS.. That first video is my exact set up even the same csr pump.. I see what he did with the alternator.. I'm probably going to do the same.. Thx again.
Old Sep 20, 2013 | 07:00 PM
1qk4mula's Avatar
You can't install the Lt1 balancer when using gmpp front plug/opti spark delete cover.. That front cover is made to be used with the 6.75" sbc balancer..... That's the whole problem I'm having with running a traditional sbc distributor on top of the intake.. That's what this whole thread is about..
Old Sep 20, 2013 | 07:08 PM
1qk4mula's Avatar
"Part # 12367600
Covers hole on front cover of engine when original distributor is removed and replaced with rear mounted distributor.
Old Sep 20, 2013 | 08:40 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
As said above run the low mount alt. bracket.
http://alangrovecomponents.carshopin...s_id/3458/227R
Old Sep 20, 2013 | 09:18 PM
1qk4mula's Avatar
I like that bracket and that's where I want my alternator.. But you CAN NOT use the lt1 balancer when you use the opti delete cover. The timing tab is in the way. It's made to work with the sbc balancer so that you can time the engine.. Then when u install the crank pulley onto the sbc balancer the alternator needs to sit more forward so that the belt lines up with pulley..
Old Sep 20, 2013 | 09:26 PM
1qk4mula's Avatar
I might be able to put spacers between that bracket and the block to move the alternator forward... I might try that.. Thx fstfbdy for the link... Much appreciated.
Old Sep 20, 2013 | 09:47 PM
Car: '90 Camaro
Engine: 305 tbi
no problamo!
do you have pics of your motor for everyone to see
Old Sep 21, 2013 | 12:38 AM
Car: 1990 Camaro RS
I may be incorrect but wouldn't the lt1 hub space the balancer out far enough for it to work?
Old Sep 21, 2013 | 09:12 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
sell that timing cover. get a stock lt1 and weld the holes shut like I did on mine. Then fab up a pointer. use all the sock LT1 accessories. Problems solved. Im running a MSD distributor in the boosted LT1 setup. (stock 92 pcm with $59 code for boosted cars)
Old Sep 21, 2013 | 09:17 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
run a tab n cover like this..
http://img843.imageshack.us/img843/8164/img0239d.jpg
http://img23.imageshack.us/img23/7646/img0247kl.jpg
http://img510.imageshack.us/img510/5092/img0238hz.jpg
More.
http://i31.photobucket.com/albums/c3...APR07003-1.jpg
http://i31.photobucket.com/albums/c3...APR07005-1.jpg
Old Sep 21, 2013 | 06:19 PM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Why not just run an aftermarket balancer that is the right size like an ATI unit? I know it is expensive at $410, but it will work and you can use all the LT1 stuff and not have to mix and match stuff. Also can probably find a used one or call Jegs and ask what size their 10% under drive LT1 pulley is. Here is a link to the ATI damper at Jegs: http://www.jegs.com/i/ATI/085/917271/10002/-1It has timing marks on it and adds a better damper than stock. I have used it on some LT1 cars and have had good results, but never used it on a carb setup.
Old Sep 29, 2013 | 10:23 PM
Eastside_gizz's Avatar
Car: 92 firebird
Engine: 350 lt-1
Transmission: 700 r-4
i did mine using the factory accesory bracket and modding it. I have a lt1 ps pump and the lt1 altenator.(dont know if theyre different). a little cutting and shimming and its fairly simple operation.
Attached Thumbnails Am I the only guy who has a carbed Lt1???-20130929_224716.jpg   Am I the only guy who has a carbed Lt1???-20130929_224409.jpg   Am I the only guy who has a carbed Lt1???-20130929_224925.jpg
Old Sep 29, 2013 | 10:29 PM
Car: 92 firebird
Engine: 350 lt-1
also I have a normal sbc timing chain cover with a little fabbed cover to cover the top theres no pressure in the little cover that silicone won't seal. with a summit balancer and march pully. The motor gets high revs often and I havent thrown a belt or chewed one up in 5yrs.
Attached Thumbnails Am I the only guy who has a carbed Lt1???-lt1-2.jpg   Am I the only guy who has a carbed Lt1???-lt1-1.jpg
Old Oct 1, 2013 | 09:58 PM
1qk4mula's Avatar
Thx east side . I like your set up. I might do it like that..
Btw what intake are you using there? It looks like gmpp.. Was it hard to adapt? Are the bolt angles the same?
Old Oct 16, 2013 | 10:52 PM
Car: 92 firebird
Engine: 350 lt-1
its a gmpp vortec intake. we blocked off the cooling ports and it only uses the outer for bolts..so far no leaks..other than that it bolted right up. I'm thinking of machining the other holes but if its not leaking im not going to mess with it.
Old Oct 17, 2013 | 05:05 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Eastside. looks nice. Just curious why you went thru all you did with intake and timing cover,etc. to run a carbed LT1 vs just building a gen1 sbc? Just for rev. cooling and aluminum heads? Something you had laying around?
Old Oct 21, 2013 | 05:37 PM
Car: 92 firebird
Engine: 350 lt-1
Mainly had the stuff laying around my buddy's garage. but overall yes rev cooling is a huge thing but better pistons and rods (stock), better heads, roller motor, overall a better motor in my opinion for anyone wondering some differences. I have a stock rotating assembly, some home ported heads, cam, and that crazy intake and the car will go in the 11's all day. pump gas and never gets over 180.
Old Oct 21, 2013 | 06:35 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
nice.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
86IROC112
Aug 17, 2015 02:00 PM
Street Lethal
Aug 14, 2015 08:25 PM
