5.3 vortec plugs
Old Sep 12, 2013 | 01:45 PM
adamrivera94's Avatar
5.3 vortec plugs
Need to know where these plugs go
Old Sep 16, 2013 | 09:05 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: 5.3 vortec plugs
Purple- Starter
2nd pic- Crank
3rd-Transmission
4th-Transmission
5th-im not sure if thats coolant or TPS
6th-MAF
Thats going from memory but i think im 80% right.
Old Sep 16, 2013 | 09:16 PM
Originally Posted by Brando5641
Purple- Starter
2nd pic- Crank
3rd-Transmission
4th-Transmission
6th-MAF
Okay so does the purple wire go straight I the battery or to ignition?
Where is the crank sensor located?
Where is the maf sensor located?
Old Sep 16, 2013 | 09:43 PM
Pocket's Avatar
Car: 91 Trans Am
Lg ppl is starter. It's the small terminal. The large lug gets the battery cable
Second is MAP not crank. It has a gray body with grn, gry, and orn/blk wires. MAP is on the top of the truck intake, rear of a car intake. Crank is behind the starter on the block
3rd and 4th are trans range switch from the truck. Not used for the swap
5th looks like VSS. Ppl and grn wires right?
Last is MAF. It goes in you intake tract. Do a google search for 85mm MAF if you need a picture
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Amillionoh7
Sep 11, 2015 11:36 AM
Jlanz55
Sep 9, 2015 09:09 AM
