picked up another LT1, budget pistons for 355?
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Hey guys, I picked up another LT1 (95 "327" block) from a friend of mine and I have a question. I guess the owner who had it before the guy I bought it from was a big fan of the nitrous. When I pulled the motor apart the number 8 piston had a lovely chunk missing from it due to a lean spray condition. Luckily the rest of the bottom end is in pristine condition. There's barely any wear on ANY of the main, cam and rod bearings. So that leaves me with boring and honing the block for new pistons. What would you guys recommend for a decent piston? The car is going to be a daily driver so it doesn't have to be ridiculous. I MIGHT and I mean MIGHT want to put a turbo with low boost on it in the future. So there you have it. What do you guys have in mind?
Re: picked up another LT1, budget pistons for 355?
Pick your favorite SBC brand. FWIW, I'd punch it out the minimum needed like .005-.010, then order pistons. Punching it out to .030 from the start is a waste
Car: berlinetta
Engine: Lt1
Transmission: t56
id have to agree with pocket with boring it I went .020 only as needed (water damage) if needed I do have the stock pistons in good shape if u can just hone the block id just give u if that's the best for u let me know
I'm going to drop the block off to a reputable machine shop here in town to have the block checked out. If I'm get lucky and they can just clean it up with a hone I'll definitely hit you up for those pistons.
Well it looks like it did need a pretty heavy boring out. The scratches and water damage went deeper than the visible eye could pick up. So it did end up getting bored 30 over. From the research I've done most LT1 style pistons are "lighter" than standard sbc pistons. I've honestly never purchased pistons on their own before. Do they sell piston/ring combos? Any recommendations?
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Yes they sell piston/ring kits. If you are looking for an OE style piston Summit has a set for less than a hundred bucks but I don't know for sure if the rings come with them. LT1 uses metric rings, gen 1 SBC uses standard rings.
Check out northernautoparts.com They have good prices too.
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Yes they wo u ld be the ones....
As far as rings, that will depend on the use.. i use low tension rings
Ok how do you think those piston would work in a low boost application? The idea of a GT45 keeps itching at me. What style rings would work with that? I apologize for all of the questions but the boost realm is very new to me.
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
If planning on boost, stay away from the light/budget forgings, such as TRW or Speed-Pro. Boosted cars can get into detonation very easily & you want a little margin of safety.
While more expensive, I prefer the SRP pistons for up to about 700hp, above this I generally step up to the JE's.
Wiseco also makes a decent medium cost piston if you are not planning anything crazy. Just keep in mind any boosted application with a poor tune can break just about any piston (or other internal part) for that matter.
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
