Using Factory LS1 Oil Pressure Sending Unit for Gauge
Old Nov 11, 2013 | 11:47 PM
cowansauto's Avatar
What are your gauge readings when using the factory LS1 oil pressure sending unit instead of re-using the factory 3rd Gen sending unit?
I've had a hard time finding an adaptor fitting for my factory sending unit. The original one on my 1991 is a 1/4" NPT I believe. I still have the one that came out of my 99 Camaro LS1 engine.
Old Nov 12, 2013 | 04:55 AM
UR50SLO's Avatar
Car: 86 Turbo Camaro
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
Re: Using Factory LS1 Oil Pressure Sending Unit for Gauge
On the drivers side of your pan there should be a fitting with two bolts on it.... You can take that off... drill and tap for 1/8pipe (NPT) and put your stock 3d gen sending unit right
in there.
Hope that helps,
Scott~
Old Nov 12, 2013 | 07:08 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Autometer carries the bushings you need to put an 1/8" NPT fitting into the LS series blocks. They arent that expensive... I think i also found them on McMaster Carr/Grainger.
Another option is to destroy the LS1 sender, drill the metal part and tap it. I think Ive seen a few guys do that with success.
And what UR50SLO said is also another option. That'll work good too.
J.
Old Nov 12, 2013 | 07:28 AM
drduster's Avatar
Car: '88 Iroc-Z
Axle/Gears: 3.23 posi 10 bolt
I used a 4th gen (2002 LS1) sending unit on my conversion. It's a one wire connection that goes to your gauge through the 3rd gen harness. I can't help with a comparison of readings between the 3rd & 4th gen senders, but I've never questioned the reading on my stock 3rd gen gauge.
Old Nov 12, 2013 | 08:39 AM
cowansauto's Avatar
Thanks for the fast replies!
I've got the AutoMeter adaptor now but 1/8" pipe is too small for the new sender I bought from the parts store. Evidentially there are two sizes of senders on the original blocks, 1/8 pipe and 1/4?
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
