LS1 rebuild or not?
Old Nov 13, 2013 | 12:25 AM
ace322's Avatar
LS1 rebuild or not?
I've been thinking about purchasing a ls1 block and heads for 500 bucks. Heads come with all moving parts and the block just comes with the crank. Not sure whether to pull the trigger or not. Anyone have any advice how much it costs to rebuild an LS1 and is it worth the time and money to eventually swap it into my third gen camaro? Any input would really help
Old Nov 13, 2013 | 08:52 AM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: LS1 rebuild or not?
get it you can get a 383 stroker kit for around 800 for a LS motor or all the rotating parts with new pistons for arouns 800 still way under the asking price of a LS motor
just very carfully inspect the block for cracks
Old Nov 13, 2013 | 08:35 PM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Just a quick question for you. Where are you finding a 383 LS kit for $800 or was that a typo? Never seen a price that low for them.
Old Nov 14, 2013 | 09:27 AM
lunati397's Avatar
wasnt a typo Ohio crank and rotating assy because of an overstock and were getting rid of them cheap all forged too was on their site and on racing junk
Old Nov 14, 2013 | 03:09 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Cost depends on how good you want it to be. Using stock bits it can be uber cheap. Forging can be reasonable or you can spend 5K on a crank alone.
Set power goals, how much your willing to spend, then we can help
Old Nov 15, 2013 | 10:57 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
That's pretty cheap are the already balance etc if I'm not mistaking some Ls 383 kits still need some machine work,balancing etc but I could be wrong it was awhile back when I was researching for kits
What's your budget ?
Also I wouldn't trust any shop to build a LS engine especially if the quote you a $500 rebuild special
If block checks out expect to pay at least 1000-1500 on all machine work and labor but your missing rods pistons etc so depending on what route using stock parts or going forged etc price may adjust accordingly it will also change on how much you do yourself also
I paid about 1400ish to rebuild my short block with stock rotating assembly new rings, arp rod bolts, etc just to give you a idea
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
