6.0 swap now I cant get my speedometer to work
Old Nov 21, 2013 | 04:30 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
I finally got my 6.0 in and we are in the process of tuning it. I need to know where the red connector, terminal 50 grn wire hooks up on my car. The lap top will read the mph but my speedometer does nothing, Has anyone had this problem?
Old Nov 21, 2013 | 05:04 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 6.0 swap now I cant get my speedometer to work
Depends on what your car came with originally
82-89 camaros require a cable driver box. Hook it directly to the input wire, then add 12v and ground
90-92 camaros had electric speedos. V6 and TPI cars hook it directly to C207 pin D (GRY). TBI cars hook it to C207 pin K (BRN) and bypass the buffer box by connecting pins C&F
82-86 Firebirds were cable driven, see above
87-89 firebirds were all wired with the buffer box regardless of engine. See above
90-92 firebirds, same as camaros
Theres all you need to know about speedo wiring for LT1/LSx swaps for all 3rd gens. From now on Im going to link this thread instead of typing it out every time
If your gauge does nothing still, check the conversion factor from trans to trans. A forgotten 4L60E value in a T56 tune (or reverse) will make the speedo do crazy things, or nothing at all
Old Nov 22, 2013 | 09:21 AM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Thanks Pocket, this car had the tpi but when I went to 383 carb I removed all the computer harness including trans harness. Do you have a schematic of the gauge cluster or some way I can find that gray wire behind my instrument panel?
Old Nov 22, 2013 | 04:25 PM
Pocket's Avatar
Car: 91 Trans Am
Pin listed is for the C207. Its a clear connector(engine side) and split black connector(dash side) near the old ECM. Cant imagine any reason that would be cut out
Its pin A (BRN or GRY) on the drivers side connector of the cluster for camaros
Old Nov 23, 2013 | 09:28 AM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Thanks again thats what I needed to know, now maybe I can get this speedo working I will let you know after I get another chance to work on it.
Old Nov 24, 2013 | 04:17 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Thanks Pocket now I have a working speedometer.
Old Mar 27, 2014 | 04:29 PM
tony_tidrick's Avatar
I just finished putting my 6.0 ls in my 92 camaro and i cant get the speedo to work.does anyone know what wires on the new pcm which is out of a 02 chev truck i hook up the purple and yellow wires to. I have them hooked up to the existing speed sensor wires that are on the 4l60e and my speedo just jumps around.
Old Mar 27, 2014 | 07:34 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Why? the 4l60e is already connected to the new pcm right,that is how the ecm knows the speed you are going. All you need is the speedo output wire from the new ecm and wire it directly to the speedo gauge wire.As pocket mentioned above for the 90-92 camaros you are bypassing the buffer box.
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
jharrison5
Aug 19, 2015 05:53 PM
ChevyZ71
Aug 13, 2015 07:30 AM
marcusaw
Aug 10, 2015 08:13 AM
