Radiator Opinions
Car: 1988 Camaro
Engine: 5.3L LM7
Axle/Gears: 3.73 1LE '90 Disc
Radiator Opinions
Hey Guys,
Just wanted solicit opinions. I have to buy a new radiator for my 88 Camaro (originally a 305/auto car), doing a 5.3 truck swap with Fbody LS1 drive accessories.
I've been looking at the Champion CC-951 and American Eagle AE951 radiators. Would you all suggest anything different?
I also didn't know if I would need anything different for in/out flow of the ls1 water pump in a radiator.
Thanks,
Bryan
Thanks,
Bryan
Transmission: 4L80E/4L80E
Not sure of exact statistics, but I'd guess over half of LS 3rd gen swappers use a factory-type 3rd gen radiator.
You'll need hoses from something other than an f-body to use a 3rd gen radiator. But, not that difficult.
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: Radiator Opinions
Im using stock 86 305 carb rad on my cammed lq4.Not a glitch in regulating temps 5yrs strong.I doubt you need anything fancy unless you got a heavily modded motor/boost.
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
I am running the 3 row Champion CC-951 myself and have been very happy with the rad.
Throw away the rad cap that comes with it, likely will not be reusable by the time you get it off anyway. Rad fits really well after you modify the rubber mounts and it does a very great job of keeping things cool. Fits with a/c condenser in place as well. Heat isn't really an issue with the LS motors, but was in my previous 406 SBC setup, which I never ran into any problems once this rad was installed.
One nice addition the Champion rad has over the stock rad for the LS installation is a connection point for the LS engine coolant X-over line. (See pic attached of connection point)
Check out Ebay for discount pricing.
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Stock radiator. 180* thermostat. Works fine.
Sent my custom Griffin off with my 383, when I sold it.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
