need help with conector
Old Jan 18, 2014 | 10:12 AM
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
Engine: 355
I started my Ls swap on my Camaro and been working on the wiring but I can't find the other side of this connector and was wondering if any know where or what it is.
Harness is of a 04 silverado
Old Jan 18, 2014 | 01:02 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
Re: need help with conector
Black wire with white stripe is a ground, grey wire with black stripe is 4x4LOW engage signal to PCM, I forget what brown is for right off hand.
This connector can be removed and discarded fr the harness, it's nothing pertinent or useful to a thirdgen swap.
Old Jan 19, 2014 | 08:13 AM
Engine: 355
Thank you for response my project was stopped because I couldn't figure this out now I can get back to it
Old Jan 19, 2014 | 11:35 AM
Engine: 355
OK guys one more connector. Any clue?
Attached Thumbnails need help with conector-forumrunner_20140119_113537.png   need help with conector-forumrunner_20140119_113548.png
Old Jan 19, 2014 | 12:16 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Are you trying to use the truck fuse block as well?
I looked a a few harnesses I have here, and didn't see that connector anywhere in a engine harness, but I did find that connector in a partial body harness from a 04 I have. Sorry I can't help you with that one, I'm not sure what it is.
Old Jan 19, 2014 | 07:05 PM
Engine: 355
Believe or not I'm using the entire writing of the truck. The car had no wiring at all
Old Jan 19, 2014 | 09:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Trace the wires back to the PCM connector and get the pin location.
If they don't go back to the PCM, you don't need them.
400Z28Racer
May 17, 2003 10:49 AM
RedWagon42
Dec 23, 2002 12:57 PM
